Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
0 Members and 19 Guests are viewing this topic.
armagdn03
man you guys are making things complicated.
I wish I could turn my brain off sometimes, then I could get some sleep.
giantkiller
Quote from: sparks on May 23, 2008, 10:14:04 AM
@ GK
    So  in this configuration  where would you be able to extract translatory energy that it can be used for doing work?
One thing I saw I believe is cold energy is The irf840 are maxed at 8 amps. The meter spends all it measuring moments in overload which is 10amps max. The fet is only warm to the touch. Go figure. Another small indicator of what was apperent but not. I can also doulble up or parallel quad the fets.
I test with 2 to 4 amps with this strange waveform. I then go bigger in successive steps. I got 30 irf840-s. And the volt meter on my atv battery reads negative even though it is connected positive.
There will be more results today.
--giantkiller. I have seen too many complimentary things with this set up.
sparks
@GK
   Armageddon is right.  It's a little overkill to demonstrate free energy.
Instead of just looking at the ouput with a high impedance device like a battery or an oscilliscope a small electric motor or a number of light bulbs says so much more.   Think outside the box brother I know you have what it takes.  The tpu ain't worth shit if all it does is runaway with itself.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
That is true.
The basis for what I have is Otto's 1 wire coil tests.
--giantkiller. I am simply pulling from the past.
ketone
