Thanks to ALL for your help!!
Gravity wheel by sevich
Started by FreeEnergy, October 01, 2007, 07:34:26 AM
AB Hammer
Lets look at it closely
If you can get it to work? It would have to be very large to produce any power.
Now lets try something else your gears would have to move at an angle to place the ball on the inside of the wheel ( more like a spiro gear ) and then you would have to have enough energy to spin it with gearing along the rim of the wheel and that would take more energy than you can give. with those size balls. So go with bigger balls and put on AC DC while you build it. ;D
Alan
wattsup
In general a large wheel turing a small wheel requires more energy than a small wheel turning a large wheel. Two small wheels makes things worst. Plus lifting two weights makes it impossible.
First, the big wheel would have to be perfectly balanced.
The small wheels should lift the balls but not at the same time. This cuts down the maximum energy requirement.
But all in all, given friction considerations for such a design to mechaincally work, I'd say don't waste your time. Don't take this as a knock down to then get personally challenged to prove us wrong. because you'll be wasting time.
Don't build anything that does not seem sound on paper from all angles at 99%. Right now this idea is at 10%.
sevich
@ Wattsup
QuoteDon't build anything that does not seem sound on paper from all angles at 99%. Right now this idea is at 10%
consider it done! .....just contemplating an actual build was a brain drain....umming & rrring did'nt help!!
nwman
Not too stretch this thread any longer but I have worked on very similar ideas in the past and I mathematically have broken down about 95% of it to express the physics behind an over balanced wheel. To say the least it shows (not proves) that a OU wheel will not work. Its simple 100% calculable math. However if the answer is mathematically possible they would have figured it out already. If that answer is there current math will not express it.
Tim
