TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
z_p_e
Quote from: Earl on October 07, 2007, 02:30:36 PM
If the Earth did not rotate, gravity alone would not cause any water vortexes.
Indeed water does not require the rotation of the earth to rotate into a vortex. As long as gravity is present, the water will form into a vortex on its own, but the vortex direction will be determined by chaotic imperfections in the holding container, and hence will be random on a case by case basis.
In fact, water can be "encouraged" to rotate in a direction opposite its natural tendency due to the earth's rotation, simply by stirring it up manually before "pulling the plug".
So for all intents and purposes, water will form into a vortex under the influence of a rotating earth or not...as long as "gravity" is present.
Quote from: z_p_e on October 07, 2007, 12:59:34 PM
Since gravity does not affect a magnetic field, how can gravity come into play in an electromagnetic device?
Do you understand that your body is NOT being attracted to planet Earth?
Do you understand that your body is being PUSHED to planet Earth by aether flow?
Do you understand that the Moon is NOT orbiting Earth because of mutual attraction balancing centrifugal force?
Can you visualize a thin flat stretched rubber sheet with planet Earth causing a deformation in this surface and in this indented cone the moon is rolling around?  Should the Moon's velocity increase it would rise up towards the rubber surface.  As the Moon's velocity increases further it continues up the cone until it reaches the rubber surface, at which point it no longer orbits the Earth, but flies off into space.  Astronomers call this escape velocity.
THERE IS NO SUCH THING AS GRAVITATIONAL ATTRACTION.
Gravity is only a "symptom" of the flow of aether caused by space-time deformation.  Mass causes space-time to deform.
Electrostatic potential and electrodynamic rotation are know to cause space-time deformation.
This fictional term gravity can be equated to chariots pulling celestial bodies across the sky.  Gravity as two bodies attracting each other, as you think of it, does not exist.
Think of the 2-D rubber sheet example above, then wrap your mind around a 3-D version of it.  You will then be able to start understanding aether and space-time deformations.
Can you visualize in the 2-D rubber sheet example, that you are sitting on Earth's surface and your TPU with it's rotating vortex,   and all of a sudden the cone on which the Earth is depressed starts deforming.  First a little dimple, then a long finger, then it gets bigger and wow, the rubber surface stretches and forms a cone right into the center of your TPU.  The TPU has synthesized a virtual mass so great that it deforms space-time.
So yes, gravity can be involved in the TPU, even though gravity does not exist.  ;)
Regards, Earl
Call "gravity" whatever you wish; its effect is what matters, and the fact that gravity has no significant effect on electromagnetics,  can only mean the TPU does not operate on any principles involving gravity.
I'd be happy to entertain the idea of a gravity-magnetism interaction, and if you were able to intelligently elaborate on one, you'd surely be up for a Nobel prize.
BEP
Interesting arguments - all. I'll put my two cents in just to hear the change jingle.
Yes, you can stir it the wrong direction and it will go down the drain still rotating that direction. However, if you have enough flow to watch at some point the vortex loose momentum and will correct the direction and wind up rotating the way it would have without interference. I don't remember how old I was when I tried this but I was short enough to watch it happen in a milk carrier. That would probably put me around 6 or 7.
I remember watching a PBS show about slow motion photography. Some of the examples were dealing with water flow. One showed water being pumped out a spigot that was miles from the pump. When they showed slow-mo it was obviously coming out in pulses. The explanation was the pulse rate was that of the pump.
The same show displayed how water always has rotation when travelling through a hose even when the pump used a piston. I remember asking an ME why the coolant pumps in the plant all ran the same direction. He looked at me like I was stupid and said all pumps run in that direction unless you need it south of the equator. At that point I thought he was the one that was stupid.
Maybe I'm the one still stupid.
The point is everything - down to the particle level IS rotation. One of my favorite rants 'there is no such thing as a straight line'.
This energy I'm after is disorganized and therefore null. I need to organize it by stirring the pot the right direction. Once it is all spinning the right direction it becomes potential. In order to use that potential I need to suddenly redirect it. Since it is not possible to add or subtract from this potential I can only convert some of it by forcing a sudden change in direction.
This is amazingly simple after rotation is achieved. You just add a biased solenoid type coil at the point where the opposite rotations of the vortex meet (notice I used a singular form). The magnetic field (lack of a better word) causes the traveling particle/charge/spin to exit vertical E field at a right angle - right through the coil windings. Once in the winding's field it happily jumps in line with the current already flowing in the coil.
Against the rules induction does occur.
BTW
@Earl
When you pull that plug on the virtual drain (TPU). You better duck because not only is it draining from above but also below. And where does the dirty water go? Out the sides and drenches you ;)
My bench time today was fruitful. I now have a control coil that will only create a 'squeeze' in one direction. The function tests well as standalone. I can't wait to put it on my EMP frame but the new coil set is still in the etching tank.
What is a TPU? A wavewatcher EMP ran in reverse with a collector added and a few ounces of batteries instead of a couple hundred pounds of caps and batteries  ;D
The control coil is dirt simple and I believe some folks have used variations of it so ask if interested.
ALL of the above is my opinion. When I have a working TPU that doesn't kill me I'll stick it all on a jump drive and upload when I get to civilization. Until then or some fantastic discovery I'll not wade through server disconnects and hours of connect time for a couple of photos.
z_p_e
BEP,
Of course we're interested.
If you wouldn't mind, a description and small drawing of what you are doing with this control coil would be appreciated.
Thanks.
z_p_e
BEP,
Is this picture similar to what you are thinking here?
Picture source: http://jnaudin.free.fr/html/magvtx.htm
Naudin goes on to explore tapping this energy by placing pickup coils at the vertex:
http://jnaudin.free.fr/html/dvtgv1.htm
So you would place a solenoid where Naudin has his pickup coils?
