Negative resistance via pyroclay.com material ?
Started by hartiberlin, October 02, 2007, 10:25:37 AM
armagdn03
two sides of the same coin, since magnetism induces current, and vice versa. So basically you can consider it one and the same, just realize both are present.
I wish I could turn my brain off sometimes, then I could get some sleep.
armagdn03
and also they are talking about the "spike" of energy you see when you have an abrupt current induced, or disconnected.
RadiantEnRg
Yes...Example B is EXACTLY what I did...thanks for drawing it up...I would of eventually gotten around to it..I am just really busy with school and such. And yes as Armagdn03 said they are very similar... pulse a current through a transformer primary and you induce a current in the secondary....collapse this field(turn it off) and you get a reversed current in the secondary...hence AC.....Now the trick is speed...now think of this..... 1/0 ...as taught in algebra, you cannot divide by 0...you know why this is??...you get an undefined....I would like to re-term that...undefined=infinite.......what does 1/2 mean?...means you change 1 over 2 units of something (time in this case)...so now think of 1/0 ....you change one over 0 time...or instantaneous.....anyone have a graphing calculator??...type in under y= 1/0, then graph... now in class we are told NO...doesn't work...but your calculator knows the truth and graphs it as such....we are told that the line reaching to infinity is the asymptote...and we would get 2 separate graphs...however undefined really means infinite...(more of this in calculus)...but ya whatever you pulse in a primary you get reversed in secondary...Imagine it as a mirror of sorts.....We need to start using electricity as instantaneous spikes instead of rolling waves...if we do this then electrons will not be able to follow voltage....and we will leave the source electrons behind, as current doesn't have to follow V..(look up Fogal charged barrier)...anyway that's my lil spiel on the matter.n If anyone cares I am working on wave theory...electrons ride the waves....if the wave is not a constant (transverse wave), but instead pulsed (square wave) or even half pulsed(saw tooth wave) we can get much more energy out then put in("IF" we have something to "translate" these spikes such as caps/batteries)....well hope that helps a lil with conceptual understanding....My theory adapts the "Aether" theory of Voltage...that it is a second force completely detachable from electrons.....Old theory believes that there is infinite +/- molecules I will call them for lack of better word, that are in a seemingly chaotic "boiling" but since they are opposite and opposites attract...they balance themselves out.....when we make a open circuit...we are making a +/- charge seperate from each other and this allows us to polarizes this "aether" to asymmetry and then the lopsided aether can now pour in. Now all the work in this field (Tesla, Bearden,Bedini,Lindemann, ect) they all say that it is inverted of the electricity we are use to..instead of radiating out(what we do now) this energy is implosive is the best word..and they are reciprocal.....Hence  the term "negative energy" doesn't mean it is negatively charged...means if the energy we use now is called positive energy...then the reciprocal of that is negative....well where I am going with this is here....This energy "eats" up solid state devices.....And loves resistance(not solid state R's, but actual resistance of say a constrictive wire)....We need to start getting back to analog components, as they can hold up very well......However, a really bright electrical engineer could put a barrier between the 2 energies(photon barrier of say opto-isolators). This is the direction I am headed in, so that is why I am not making more videos.....that test proved that the instantaneos change of a square/sawtooth wave makes a HUGE spike in energy that far surpasses input...once resonance is achieved the efficiency goes up even higher.....well I must get back to work..I hope I didn't ramble too much and some find this helpful.....later guys
linda933
My theory:
Your experiment with the motor speeding up merely shows that the harmonic-rich spectrum of RF interference you create when sparking interferes with your power supply's regulation circuitry and causes the power supply output voltage to increase, thus speeding up the motor.  This is a very common phenomena in labs where RF work is done.  Until you disprove this theory (far more likely than obtaining mysterious free radiant energy), you have not shown anything anomalous.
Linda
Super
Thanks to armagdn03 and RadiantEnRg for explanation.
Hmm, you said very fast ... the problem is that in theory you can create mathematical giants (delta impulse/dirac)
but in practice you are limited by reality  :(
look i understand what you are trying to show with your experiments and i think its good work!
The bemf or magnetic collapse is like a very good dirac impulse (~infinity high, ~zero time)
thats also the principle of the bedini motor, the magnet should only generate this dirac impulse
current is not desired ... but because of this easy to rebuild design its less efficient.
So i wish you all good luck in tapping into radiant energy.
Perhaps many people have seen it already and don't realized it...
