Negative resistance via pyroclay.com material ?
Started by hartiberlin, October 02, 2007, 10:25:37 AM
linda933
I confess now that I am thoroughly spun, confused, bewildered and totally numb.  I will await your further reports with bated breath.  Glad we were able to get to here without too much bloodshed.  Have a ball with it.
I'll never understand about the batteries, the ripple sawtooth, what is supposed to be resonating with what and all that, I guess.  It makes no sense to me at all and if I ask any more questions I can tell we will just go round and round forever, so I'm going to quit while I'm behind.  I have classes tomorrow anyway. This is only a small part of my unfinished homework!
Thanks for your impatient patience and I'm glad we can "still be friends"...I hope...
Linda
RadiantEnRg
Umm, yes....your points are almost 100%
A straight battery will not work...just like the straight power supply barely worked
Umm, the small saw tooth wave form is like you said mostly DC...but going through a bifilar choke, I suspect it picks up an AC overtone.
In resonance....i am not sure it gets more energy....although if you are familiar with Bedini chargers...he does the same thing..resonating a battery lets it suck in free electrons???...My theory is more along the lines that resonance acts like a kid pushing a swing...and in the motor the commutator is making many adbrupt breaks, which allows BEMF to be used in the motor...hence the HUGE green arc inside it, (for now you will have to take my word that it was metered at 27v), If you want, you could come into my H2Earth channel maybe and ask Jeff himself???...or just wait till I get another power supply
the bead is spherical, and circles are VERY conducive of resonance....pi=3.14.....motor has 3 coils?? Just throwing some stuff out there
RadiantEnRg
The load must resonate with the circuits output.....Hence I believe the jamming is correct..but not jamming open voltage...jamming open frequency
The coil is a factor of 1...meaning one spark increents...so it tunes to resoance quite easy....the motors on the other hand....the Big `12v is balanced so it has an even increment of 2...the lill motor is off balanced...it has odd increments..so in complex ratios it can tune by 1 increment like the coil alone. This probably doesn't make sense, but I can't explain better what resonates with what...You would have to see my journal, and my notes of the lil motor's phases/sets
linda933
Try not to fry yourself, okay?  Nighty nite now!
Linda
RadiantEnRg
Sorry for the spelling errors....and I forgot the Big motor, it never truly resonates with the circuit...(due to balance)
And Linda...I get mad sometimes because I am not very good with terms, and so people try to discredit my findings because I can't phase it correctly...but, Would a rose by any other name be less beautifult?..But I assure you I am not naive. Hopeful, but not naive. Sorry for my (Pro/Hoe) comment, I get a lot of desperate/commited attempts to humiliate/refute my experiments...and it does get a lil old.
But, ya no harsh feelings...again sorry ;)
