0 Members and 25 Guests are viewing this topic.
DrStiffler
Quote from: Loki67671 on May 31, 2008, 12:27:28 PM
@All,
The visuals tell the tale for me. The spikes are me picking up and moving the temp sensors. The dip in the red trace is the sensor for H20 when I put it into the SS vessel. The other two are sitting side by side tucked just under the left corner of the monitor. Now from this I will look for overall system stability. Next I'll completely assemble it and start dumping some known energy into the mass as a whole, obviously after I water bath calibrate those temp sensors but that will simply be done after assembly.  ;D Green trace is Power input. I'll be fiddling with some additional decoupling too to smooth things out a bit further.  ;D Data is being sampled on 1 minute interval and logged into Excel.
Best regards
Jim
@Loki67671
Hey man! (new generation saying) you are going farther than you need to go here. This is great stuff and what you have setup is fantastic, but remember it you have some gear with a combined error of say 20-30% and you have an Exciter running at 2+, you got no problem.
This setup really looks good, indeed. The one minute sampling may have to be adjusted after your first calibration run, if you do not want to post the cal run, could you send it to me direct as I have a few programs that can look at it.
So you are going to monitor water temp in the heat exchanger, the temp in the chamber where the SEC is at and the ambient? Or just the water and the ambient?
Can't wait to see data, great job and thanks for all the hard work you are going to to prove this to yourself.........
Thanks...
All things are possible but some are impractical.
gotoluc
Dr. Stiffler,
this is off topic but if you don't mind could you have a look at this new video I just posted and tell me what you think.
Thanks
Luc
Link: http://www.youtube.com/watch?v=9bXMgsW7Hu4
Loki67671
Quote from: DrStiffler on May 31, 2008, 04:05:25 PM
@Loki67671
Thanks...
@Dr.Stiffler,
You are welcome sir! The data is forthcoming and yes I will send it to you. The bottom line is, first, I'm going to empirically prove this to myself with data and second lay it out in front of the world, and those that are doing the same and not sharing, for permanent record.  ;D Then I'm planning on moving away from traditional fuels and energy just as rapidly as I can. I think Luc has just given us a little boost here as well as IronHead. Thanks to you folks and everyone else involved directly and indirectly also. This is going to "Rule"! Another of the new generations terms.  8)
Best regards,
Jim
"When the water stinks, I break the dam, with Love I break it" .............Loki
"One must be completely immersed in the cold darkness to truly adore or loathe the light" .............Loki
Science, my lad, is made up of mistakes, but they are mistakes which it is useful to make, because they lead little by little to the truth." - Jules Verne
Loki67671
@Dr Stiffler,
But above all of that, thank you!  ;)
Best regards,
Jim
DrStiffler
Quote from: gotoluc on May 31, 2008, 05:07:24 PM
Dr. Stiffler,
Thanks
Luc
@gotoluc
I would not trust any readings with floating leads. I would build a LPF with an r load approx = ohms/volt for the DMM and a few 0.1uF and 0.01uF across the load R.
The arc is putting out a ton of RF and it may indeed cause the meter to error. Then to the coil is outputting RF and this could also be very significant. Try putting say a 100K and a 0.01 in parallel across the load.
I do believe in Cold Electricity, but do not in Negative Electricity as this in my mind is similar to 'antimatter' and would cause a big reaction if it were present.
Nice video, but don't have much more to offer.
