PaulLowrance
Is there anyway you can draw the circuit used in that particular video? If it's easier, maybe you could draw the circuit on paper, video it, and then upload the video at youtube. Whatever's easier. It would help a lot of people! In that circuit it seems like you have the large capacitor, source batteries, and charging batteries connected differently.
http://www.youtube.com/watch?v=BLNGc7pCqwk
Thanks,
Paul
slayer007
Quote from: PaulLowrance on November 20, 2009, 05:56:40 PM
Thanks,
Paul
The coil that is # Lb is the variable inductor.(This is also how you adjust the SEC by moving the ferrite in and out of the coil)The coil is wound around the ferrite rod 20 turns.
Ferrite rod part # 273-0102 from radioshack.
The coil L1 I wound 22 turns around 1/2 pipe then just bunched it togeather and taped it.
For L2 it would help to have a LC meter.But if you don't I would try around 35 turns around a 1/2 pcv pipe.
For L2 you can experiment with differant coil setups and sizes.
I found 22uh to 60uh worked very well.Thats if you have an LC meter to check the coils.
PaulLowrance
Thanks, but there are unknowns in that video. In video it says "positive from run batteries is going right through the exciter. Negative side of the run batteries is going to the positive side of this big capacitor, and the negative side (of the big capacitor) is going back to the exciter. Both exciters the L3 coil is gone. I have ----- plug in place. That's running back to the capacitor (big capacitor), and going to the charge battery (large car battery)."
To be honest, regarding the routes of all the batteries & large cap is all unclear. Actually it's all unclear.  :(   A drawn circuit should clarify.
Thanks if you can clarify.
Paul
slayer007
Quote from: PaulLowrance on November 20, 2009, 06:31:35 PM
Paul
Paul there is one on the next page back.
http://www.overunity.com/index.php?topic=3457.2730
Sorry about the coil labeling at the E forum Dr Stiffler relabled the coils in his circuits.
So in my video I did the same labeling as the Dr.
So Lb would be L1.
L1 would be L2
And L2 is L3.
Lol, Sorry I hope that helps ::)
PaulLowrance
That helps. You wrote that L1 has 22 turns around 1/2 pipe. Also you wrote L2 has 35 turns around a 1/2 pcv pipe and can range from 22uh to 60uh. So I'll know which ones you're talking about, can you point out what inductor A, B, and C are relative to L1, L2, or Lb?
http://globalfreeenergy.info/imgs/slayer007-circuit-q1.gif
Thanks for the help!
Paul
