Selfrunning cold electricity circuit from Dr.Stiffler
Started by hartiberlin, October 11, 2007, 05:28:41 PM
Super
Thanks Stefan  ;D
... don't know why, but this guy is a little bit suspect to me,
anyway, looking to find his circuit.
MR. Amos,
he stated, that in series with this signal generator he has a 10 KOhm
resistor and a 10 pF cap.
Assuming the cap will conduct at his used frequency,
there is still the 10 KOhm resistor as a preresistor.
So, 10 KOhm at 2 Volts is 400 mikroWatts,
probably less, beacuse you have to calculate in the duty
cycle.
So do you think you can run the LED this bright with just 400 mikroWatts ?
He stated on his description that this is a blue LED
with 2,73 Volts and 25 mA.
Maybe these are just the normal specs of the LED and
not the actual measured data at the LED, but the LED at least
looks brighter than just driving it with 400 mikroWatts.
Dr.Stiffler just answered to me regarding the choke:
"It is in series on the drain side. It is necessary."
Regarding the ferrite transformer:
"... it happens to cause the core to ring at the 4th (of 3.58mHz) and the
MOSFET starts up as a parametric pump. I adjust the phase with the FE beads
and the circuit is totally AC under its own power. Complicated to view the
thing, but with care is possible. Has a field around it that is quite large.
This is a core thing and causes a parametric feedback."
TheOne
this is impressive, i would like the plan I try it !
