Selfrunning cold electricity circuit from Dr.Stiffler
Started by hartiberlin, October 11, 2007, 05:28:41 PM
0 Members and 41 Guests are viewing this topic.
DrStiffler
Quote from: hartiberlin on November 19, 2007, 11:55:00 AM
I got a private message asking this and thought this would interest also the public:
In your last video you mentioned how the coil were no different but what you are calling coils look to be magnets, is that what they are? If not, what are they made of.
These were all these litz wire coils put onto ferrite cores.
So no magnets, just AM radio ferrite cores.
I thought first that the ferrite cores Dr. Stiffler was using would be different, which
but my old ferrite cores I already had laying around
were the same...
It just depends only on the quality Q of the resonance of the LITZ coils.
They act like high quality Q ( low bandwidth) LC tank circuits at around 1.5 to 2Mhz.
Why do you always want to muddy the water? You talk about someone putting kits together, you ask people to try this and that.
Simply put the whole concept here is to be able like 'Amigo' and many other to get a working system so we can move from there. Yet you always want to change things, bring in new idea's and secret mails to further your point of view. I think you would best serve your viewers by not only asking them to do it correctly in the beginning and you follow by doing the same.
Every time you post this kind of stuff people think this is just something to throw together from the junk box, but are you ever so wrong. Stefan why can't YOU build one like 'Amigo', 'Ossie', 'Ben', 'Travis' etc., and them interject you new or special way (after you show yours works). Really should you insert idea's that are contrary until you really have a duplicate yourself????
So now we get all the negatives the whatnots and the you siders and the me siders. PLEASE stop with this, people get there when they follow the instruction and use the right components.
All things are possible but some are impractical.
dean_mcgowan
Dr Stiffler,
Awsome, thats right.. you tell him, I mean its only his forum and if he responds negatively you have an out..
so can we now have the plan for the self powering version?
The one with no obvious power source and just a ground wire ?
Please :D
Dean
armagdn03
Quote from: DrZLowe7 on November 19, 2007, 06:41:59 AM
Just a note to all. I am just making a comment on components used. As a matter of safety do not place an electrolytic capacitor rated under 250 volts across the high voltage side of the circuit. I ounce accidentally placed a 6v capacitor in a 9v circuit and it blew up like a fire cracker. Next the diodes in circuit are not rated to handle a 200v reverse voltage. They may last a while but at sometime are due to fail. A high voltage diode should be used if you plain on running your devices for very long periods. As a standard do not operate a component at or near it maximum. I try not to exceed 50% just for longevity.
I will not be making many more posting unless asked. Or I see something some may do that is dangerous.
It should be obvious by now to most, that this circuit is another form of teslas radiant energy circuits. It was noted by tesla at many points that maximum efficiency power is noted when the dielectric in the condenser is stressed to near breaking point. Therefore, it may be more dangerous, but it is also much more efficient.
I wish I could turn my brain off sometimes, then I could get some sleep.
canam101
Quote from: RStiffler on November 19, 2007, 01:22:03 PM
And it is clear from what you have reported that that method works. Like everybody else here, I was thrilled to know that 6 people besides yourself have achieved OU with the circuit:
Associates (6) in all around the world have duplicated the OU condition to the extent that there is little doubt that it is real.
If any of the people who have achieved OU are reading this, will you please tell us exactly what circuit you used, and how you know it is OU; it is hard to measure these things from what I understand, so please tell us how you did it.
Or have you achieved the holy grail and made your device self-sustaining???
Actually, that should be pretty easy, shouldn't it? If you are lighting 50 LEDs, replace 25 of them with wires leading to a converter to change the form of the power to whatever is needed as input to the circuit. Plug the output of the converter to the input of the circuit to replace whatever is powering it now, and the world is changed forever!
We eagerly await your report.
Dear Ron,
I am now not trying to rebuilt your exact circuit as I stated before,
but are trying to understand the exact behaviour of the underlying principles, that it seems you don?t
try to study.
I tried to build it exactly like you before this and only had underunity output..
You have not yet analyzed why your circuit with just the ground wire
has lighted up.
So why does it light up ?
What is energizing your coil-cores and LEDs in this circuit example ?
Did you try to shield the ground wire with alufoil and
connect it to the aluminium pan and only grounded
the aluminium foil and the ground wire at the ground bus
bar, so the 1 Meter long ground wire could not work as an antenna ?
I have tried the exact circuit with the ground wire and at my place
nothing lights up...
And user Amigo also said, that his circuit runs at around 2 Mhz and
not higher and I also did not see any resonance higher than 2 Mhz.
So it seems your breadboard with the 2 alubackplanes and all the
stray capacitances from it seems to have a major
impact on your circuit.
So as long as you all use these special breadboards,
it will be hard to translate this circuit into a real PCB used circuit.
Also we have to understand the involved effects to scale this thing up,
but as long as your 6 replication people hide and don?t post their results,
how should we learn from them ?
I was today again at www.segor.de
and bought new transistors and litz wire, cores  and other parts.
Regards, Stefan.
