Sun-Earth Potential
Started by Grumpy, October 11, 2007, 11:17:41 PM
Grumpy
This may be the source (Sauron's source) of these images:
http://www.crystalinks.com/tuningforks.html
References lines of "magnetics" or "sound" connecting the forks.
EDIT:
added PDF
Excerpt:
QuoteNote the 'M' reversing based on the harmonics of the rods.
"M"= Male = 3 = Triad
The tone --->Reverse = "W" = Woman = Aquarius
They each appear to hold a horseshoe magnet
On it's side - Male=3=3D
Side ways -- Balance -- 3 become 2 - balance restored
Should be tuned by a male and a female
        -Frank Edwards
Sauron
Grumpy
I have heard of explanation of electricity that use the terms "male" and "female", but do not know enough to begin a discussion.  It sounds like there is a harmonic relationship that changes one into the other.  So, to say the TPU works between the "electro-magenetic" and "electro-static" may be correct.
The excerpt that is posted was interesting since it mentions 3 becoming 2 and balance being restored.  Looking at the statues, the fork image may be relational to the statues with male on the right and female on the left.
The image of the sun and earth that I posted earlier, is very similar to an image in a book title "Reality Bites Back" written by  George Racz which mentions an electric field stationary wave resonance at 14.336 Hz.  I'm sure on of the many links that George lists on the back of this book is a source of the image.
EDIT:
I believe the TPU is able to connect ot the earth's electrical field, and that this field may be a universal field.
        -Frank Edwards
hansvonlieven
G'day all,
@ acer
You wanted a reference to the resonant frequencies of the elements. Bear in mind that all atomic frequencies are expressed relative to hydrogen1, which is set at 100 MHz.
http://www.eclipse.net/~numare/nsinmrpt.htm  Just click on any element and you have everything right there. A useful tool.
As to your other question, shape and material composition do not affect frequency. Only effective length, tension in a string and volume does in say a cavity. Shape and material composition however do influence the generation of harmonics, favouring some while squashing others. In other words the sound quality (timbre) of a resonant body is determined by material and shape. The fundamental wavelength (resonant frequency) is not.
The best resource for that kind of research is an organ builder's manual from the 18th century. But be warned, not only are they hard to find they are unbelievably difficult to read because of their specialised language. Also everything regarding frequencies etc is expressed in terms of musical notation. As I said on my website, 400 pages of unadulterated "keelyspeech". Having said that, in my view there is no better reference material available for acoustic research.
Hans von Lieven
turbo
hi Grump
it is intresting you mention the 14Hz frequency because i have seen effects at this frequency in some of my experiments.
i was always thinking it had to do something with the first overtone of the Schumann Resonance frequency table.
on the other hand i also noticed effects in the 2-3 Hz range so it could be there is continuously sweeping something in between the frequencys.
like a wave that is being compressed and expanding all the time.
then it would more likely look like an elipse in stead of a perfect circle.
M.
