Working Attraction Magnet Motor on Youtube!?
Started by ken_nyus, October 15, 2007, 10:08:47 PM
zero
Actually, Its quite Brilliant :)
  The shape of the Heads go from very wide, to narrow quickly.   And since the
distance is the same as from one stator magnet to the other...
One the first stator (bottom) grabs a screw,  the 2nd stator is already starting to
pull  (and maybe even a less powerful pull from the 3rd).    Then, as the 2nd is
pulling - the bottom screw thins out, reducing its grab.   Thus the 2nd stators
able to pull the 2nd screw into place.   Then it continues up the chain.
The only sticky spot is very small - to just get it started from the 1st
point to the 2nd.   Once its got enough momentum, it seems there is
no problem keeping the cycle going.
Well, that is, if the system were designed a little more accurately.
Omnibus
Quote from: zero on October 19, 2007, 12:03:46 AM
Roughly about 1 head apart horizontal diff.
Correct. Tha pattern has to be repeated throughout, each "station" outstanding the same distance from the previous. This is what I think Bill has to improve in his setup.
sterlinga
I've posted a feuture page about this here:
http://peswiki.com/index.php/OS:Screw-Magnet_Motor
Feel free to post notice of your repolications there as you build them, whatever the results.
Feel free to help beef up the instructions, materials list, etc.
Overunity.com is a great place for chronological dialogue.  PESWiki is a good place for an organized presentation of the material.  It is a publicly editable site.
Sterling
http://freeenergynews.com and http://peswiki.com
"The best cutting-edge, clean energy news and directory service on the net."
Omnibus
It appears that the exactness of this particular distance is the crucial factor despite all the other imperfections.
billmehess
What I wanted to do was to actually build the device so that I could first hand study the actual dynamics. When you have a physical unit in front of you then you can feel the "tug' of the magnets over the screws. It is so much better than trying to guess or figure what should or is happening from diagrams and pictures.
With the device I have built I can turn the pvc about 25%. Again I will examine closely that range of screws and see how it compares with the rest of the configuration and replicate that one set of screws at a time on the surface of the pvc.
Maybe I'm wrong here but I don't believe that all this grinding is necessary. I think if this device can work ( and that's still up in the air)
then I need to replicate what is working on my device (that 25%) and replicate it.
I am going to be in Seattle, Wa. for the weekend so I won't be able to do anything with this until Monday.
