Working Attraction Magnet Motor on Youtube!?
Started by ken_nyus, October 15, 2007, 10:08:47 PM
If you compare it with a standard flux gate,
(no MFT type)
the force is much higher for the rotor-iron-piece to leave
as can be seen here in this picture from the mft directory.
All the flux still wants to hold the iron rotor piece,
so it is much more sticky:
I tried to desgin a few years back with it this magnetic train idea,
but haven?t had the time to check further into it,
You need the exact right dimensions for the stator iron "rail-pieces"
and the linearly moving "rotor-train".
Here are 2 simulation pictures from it.
But it still must be some other way designed, so there is this caliper
ring directly around a magnet inside its core, so the magnet flux
can more easily switch between the last and the next iron stator
"railtrack" piece
P.S..
My second train version:
http://overunity.com/mft/pmtrain02.gif
could probably work,
if the rail iron pieces would have some kind of triangular
shape , simular to the screws which
user xpenzif has used in his magnet screw motor.
But you could not see it in the
picture, cause this is a side view !
rice
sorry to say everyone
i just finished building this exactly like the film.  i grinded the heads perfectly, i used the same exact screws,  i used the same exact magnets,  i drew a cad template and lined everything up perfectly.  it just doesent work.  its like every other false bullsh i t  claim that has come through this site.  no offence to anyone on this site but how many other people went out and spent 50 bucks on magnets, screws, gluegun,  pipe and whatever else only to find you have built another non working magnet motor,  throw it on the pile with the other non working contraptions you have built over the years
build yourself a wind turbine or something that will actually make energy for free.  there is no free lunch
@rice
can you post a picture ?
Maybe you did something wrong ?
How did you mount your 4 stator magnets ?
Onto an iron bar bracket holder ?
It should be probably iron, not aluminium.
