Localjoe
@epiphany
Maybe bob needs to read my work .. tell me what you make of these phrases .. i know im right and how easly others could have passed over the stuff  ;D
"it will of course be
understood that there may be any number of
separate coils or layers of the wires according
to the required size and capacity of the
battery"--  Reffereing to the size of the primary wires and end product
******It has been found that by reason of winding
the couple of copper and iron wires into
40 a coil-body the current traversing the windings
of this body will produce a magnetic
field within and around the body of sufficiently
strong inductive effect for practical
utilization by means of a solenoid or second-
45 ary coil 12, as illustrated in Fig. 4 of the
drawings.
.. If one doesent realize theres two devices in the patent it may be hard to grasp how an magnetic feild inside and outside the primary is useful.. its created each time the primary wires meet through the "interposition"device and broken each time the device seperates the primary wires. Thats what creates the ac in the secondary rise collapse rise collapse ... Most of the "free energy guys" we admire have not gotten this patent right and hopefully we can share with them  ;D
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Localjoe
@Epiphany
In contrast his second device describes one set of ends of terminals 5 and 6 being permentatly soldered together no make and break. This creates a static magnetic feild that is  disturbed by a mic or telegrapic relay on the secondary wires.  See how there basicly opposites in operation
Self generating induction coil-- primary wires make and break through interposition device periodcly  and stimulates ac in secondary
Self sustaining electromagnet-  Primary wires are connected perm and mic is hooked to secondary for transmission or reciving.
        Joe
epiphany
@Joe
I hope you are right.
I placed the link to the overunity site (and this thread) in the email to Bob and said that the technology is being pursued. I hope he will chime in. I really was hoping to find a description of the coil excitation method that NS used. At this point it's a guess, and your guess is as good as anyone's ! :)
My guess is that NS may have excited the tertiary coil to affect an output onto a load tied to the 5 and 6 leads. This would be the 'raw power' mode? There maybe more than one way to get it going, but there will still be a need for the coil to become an earth energy attractor.
The stories talk of cables coming from the ground, so he could have had an ongoing excitation of the cells, but the excitation method was maybe remotely controlled? I say this, as I'm having trouble imagining burying an exciter mechanism.
This is a great mystery, and great thread that you have started!
Thank you!
Localjoe
@epiphany
Its worded very carefully i dont have time to explain now but i will later. The word interpose.. to assume a stance to interupt thats the key it says the primary wires 5 and 6 are interposed by a device so the currents can runt through them.. in english
The device interposes/interrupts the connection and allows it .. Make and Break ;D
        Joe
jeanna
Quote from: epiphany on March 27, 2008, 02:02:06 PM
Thank you!
Hi Epiphany,
I will be away tonight and can't 'chat' but I want to throw out 1 or 2 thoughts.
1) As soon as the cell is moist there is a galvanic reax going on. You can play with it (collect it in a cap, use it for make and break  etc.) but you will not stop it until the coil dries out.
2) I have had an idea for a while now about those cables from a distance. I think it is possible that NS added one galvanic amount (0.7vdc or so) to a coil's juice by connecting the stake of the coil to one a distance of 30 ft away. I haven't been able to try it so I didn't mention it. but anyway,
If you have a coil with a zinc coated spike, and you connect just the spike to a copper pipe 30 feet away you will have a starter of 0.7vdc. That is voltage running to the core piece 1,  which becomes the magnet "holder" if you will.
Now add to this the current and voltage produced by the 'convolutions ' of the coil and you have just given your coil a bit of a boost. (theory only-remember) Now you have extra magnetism and possibly extra voltage.
OK, am going to a lecture tonight. I will check in tomorrow.
jeanna
EDIT
OK It is now  tomorrow ( ;) ) and I want to add one more thought.
It is very likely that the magnetic currents of the earth system will be what adds to the electricity available from the coil, and that just putting the stake into the earth will be enough to increase this. I don't want to throw anyone off, it was just a "what if" I have on my list that I mentioned above, because it seemed relevant.
j
