tak22
pitchblende (radioactive) + copper coils = magnification = William N. Barbat
tak
hansvonlieven
Thanks for the information tak,
Here is the link to Barbat's invention http://www.rexresearch.com/barbat/barbat.htm
Fascinating stuff, this might explain a lot!
Hans von Lieven
hansvonlieven
Quote from Barbat:
QuoteThis disclosure introduces a technical field in which practical electrical energy is created in accordance with the overlooked exception to the energy-conservation rule that Herman von Helmholtz described in his 1847 doctrine on energy conservation: "If . . . bodies possess forces which depend upon time and velocity, or which act in directions other than lines which unite each pair of material points, . . . then combinations of such bodies are possible in which force may be either lost or gained ad infinitum." A transverse inductive force qualifies for Helmholtz's ad infinitum rule, but this force is not sufficient of itself to cause a greater energy output than input when applied to electrons of normal mass due to their unique charge-to-mass ratio. However, the increased acceleration of conduction electrons of less-than-normal inertial mass, as occurs in photoconductors, doped semiconductors, and superconductors, is proportional to the normal electron mass divided by the low electron mass, and the magnification of harnessable inductive energy is proportional to the greater relative acceleration, squared.
Magnetic force also satisfies Helmholtz's exemption to the energy-conservation rule because magnetic force is transverse to the force that causes it, and magnetic force is determined by the "relative velocity" (i.e., perpendicular to the connecting line) between electric charges. Magnification of magnetic force and energy was demonstrated by E. Leimer (1915) in the coil of a speaker phone and in the coil of a galvanometer when he irradiated a radio antenna-wire with radium. A 10-milligram, linear radium source produced a measured 2.6-fold increase in electrical current in the antenna-wire in comparing inaudible radio reception without radium to audible reception with radium. This represented a (2.6).sup.2=7.times. increase in electrical energy flowing through the respective wire coils. The possibility of this enhanced reception being attributed to a person's body holding the unit of radium to the wire was eliminated by Leimer's additional observation that, whenever the orientation of the small radium unit was changed to approximately 30 degrees relative to the wire, the energy enhancement ceased.
Helmholtz again!
This gets wilder and wilder. Keely's and to some degree Tesla's work is largely based on Helmholtz's discoveries, so it would appear is Stubblefield's.
We are really opening a can of worms here, the implications of which are at present beyond my comprehension.
Hans von Lieven
Pirate88179
Hans:
This is fantastic!!!!  My head is reeling and I will need to go back and read all of this again.  Who the heck knows what will turn up next? Started with pipes in the ground, electrodes, Stubblefield, Keely, Tesla, Hemholtz, radioactivity, trees, poison potatos, and......?
Localjoe, you may have started something here that might take us all beyond anything we ever even considered before.  We can keep the technology open source, but I think we should SELL the book and movie rights...ha ha.
I have to go out on an assignment now but I can't wait to check this topic when I return.
hansvonlieven
Don't hold your breath Bill,
I have some serious reading and thinking to do. :-) It might take a while.
Hans
