Pirate88179
FatBird:
Welcome aboard!  You raise some good questions.  My initial response is this: Since we don't really know what is happening, then we can't really say what it isn't.  We had a couple of folks use a scope but I think the results were inconclusive on the ac being actual ac. (If I remember correctly)
I, personally, don't think that our coils would function with insulated wire.  But, I have not tried it.  I am low on wire, and a lot of other supplies at the moment.  They sure would be easier to wind if they did.  Why not give it a try and let us know?  I suggest an attempt on a smaller scale first, just to see.  I like the idea of a Quaker Oats sized coil...that's for me, ha ha.  Actually, to rule out galvanic on the coils, only one wire need be insulated, like the copper, easier to get.  I think this was discussed way back somewhere and Hans had some good thoughts on this.
The more folks experimenting, the better off we will be.  Again, welcome to our group.
jeanna
Quote from: FatBird on April 24, 2008, 11:41:01 AM
Hi fatbird,
It happens that some time ago I made a non0galvanic series of coils, and I have 1 that could work so
Quote1.  Make your Coil with insulated wire, NOT bare wire.
tele wire ~24g plastic insulated bifilar with 24g steel wire
Quote2.  Wind the Coil on a non metal core, such as cardboard or plastic.
wound around a drinking straw. now this is only 1/4 inch diameter not 4 inches like the oatbox.
Quote5.  Turn your Meter to AC Volts.
my meter only reads to .1 volt ac. but it is on now.
Quotebucket of water
It is small so it is in a glass of water (filtered) on the kitchen table.
Quote7.  Give it AT LEAST 30 MINUTES in each place to maximize the voltage in each place.
t is entirely possible that your Earth Battery Coils are TRYING to tap into the Aether Vortex Spin?
ok we'll see
here is a ? 4 u: Is there a direction I need to put the cap to get the ac and not the dc? and I assume you are talking about a regular polarized cap that dumps fast?
jeanna
FatBird
A Non Polarized Cap can be inserted either way, as there are NO  +  or  -  Markings on it.  This is what I am recommending here.
Caps with a  +  &  -  are called Polarized Caps & they DO have  +  &  -  markings on them.
As for value, I recommend a .01uf or larger value.
jeanna
Thanks for that fatbird,
I needed that cleared up in general, so thanks.
My meter is reading a steady 00.0vac  Of course it there is anything below 50mv nothing will show up.
I want to ask you why the ether vortex should notice this thing. and why it needs to be in water? if there is not even any galvanic reaction going on, why would there be any movement of anything at all?
I could concentrate on it, but I think I will let it be just see what happens  8) .
jeanna
Localjoe
@Fatbird
             Welcome and thanks for your opening thoughts.  Were all pretty much convinced its not just a galvinc rx becasue of the difference in readings from a standing cup of water vs teh cell in earth.  The earth always wins with the same cell.  This device is a transformer what were workign on currently. It takes the inital voltage and ampreage from galvinc rx and when those wires are switched on and off they create and impulse of alternating currents in the secondary coil wound around the whole thing.. Simple concept, now were just filling our measuring cups with the right lengths of wire ect for a ballsy output, as well a switching device prefreably passive has yet to be devoloped so doors are open for that one.
        Joe
nathan stubblefield pat =  600 457
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
