Pirate88179
kukulcangod
Bill:
      I wasn't clear myself I apologize, thank you for taking the time to explain I was having a hard time lighting up my 3.5v blue leds and also just to confirm what you already know a capacitor of any value will make my led brighter ,from my EB Im only getting 2.5 ma at the most before the magnesium rod and the walmart blocks I was getting .700ma -.400ma I think then I need one more carbon rod or cells hook up in series to get more ma's .
So you are talking about thirteen hundred volts out a Joule Thief? but that's with and AA battery isn't it? I'm more into getting the fuji circuit to work with the EB , so my 4 supercaps of 2.5 and 10F be here next week so I can get that 40watt neon lamp to work.
I have observed that my EB puts out more ma and voltaje during and after raining its been raining here for 3 weeks georgia that is, my opinion is that we get both effects the galvanic and the telluric currents .
Again your results are remarkable keep up the good work.
The Smithsonian Museum holds the inventions of Alfred Vail(stephen was the brother vicepresident of at&t)whom also experimented with the EB,probably a battery remains among the relics, I know that he was the one finalizing the code and the design of the telegraph, more "practical" matters probably made them forget about the EB.....whom in 1837 partnered with F.B. Morse,he was a mechanical genius, I haven't had the chance to check it out myself(even ancestors despite the trades inherited go in a very different way) despite the fact that im close to his ancestors just a tremendous coincidence ,hopefully this info will bring more light into the subject.
Best Regards
gadgetmall
@All
  This is the latest Data Graph Showing Difference in Spacing and also the pseudo-sine fundamental frequency with lower frequency bursts from Greg in the Black hill NC  c/o ASRF research file. HE  analytically overlayed an ideal sinewave, confirmed the test, and did not pursue . ASRF-EC-X22, lower graph. The Test are done using  one inch Diameter one foot long Magnesium rod and one Pure carbon rod of equal size . What We have determined with scientific data logging  is the output decreases with rain and moisture .Its Like battery terminals shorting out when water gets between them . On the other hand i have done the same test with two glasses of water and noticed when i put the water directly on the rod the amperage increases as does the voltage but when water is put between the rods and the moisture "connects" it drops the current and voltage dramatically . When the Ground  drys out then the voltage and amps return. . I have done a 7 day test With My earth battery  with dual mag rods and one carbon fiber rod and one pure carbon rod charging  a very large Ultra cap(650 farads 2.7 volts) that i sell in My store  and it has lit two jts up with several bright leds on  and the voltage remaining  today  the 8th day is Exactly  one volt steady.  The Amperage is off the scale as these caps when even the slightest charge have enough amps to pop a 10 amp fuse . When fully charged without a Jt and the voltage reaches 2.7 volts the cap can burn lamp wire in half if shorted  !! My Next Test will be a week long test with My day night circuit that turns off the Jt in the daytime using a small solar panel rather than a Cadmium photocells these are hazardous  to the environment if they break or water washes the cadmium in the ground. . the Advantage of using a solar cell is that if there is any direct light it will be routed to the ultra capacitor as an extra kick . I suspect this setup will run forever but my test will be for 7 days . Anyone interested in My Circuit  its posted in Pirates  jule Thief thread  and if interested in replication i have all the parts in My store and i can post My Schematic here . Just give me a pm .
Gadget
Pirate88179
No apology needed.
I want to be clear about something with the leds and the EB.  First, our research (on the EB groups and the JT groups) have discovered that leds will light from mostly voltage and it can be ac or dc they don't seem to care.  My Fuji circuit powered only by the earth battery puts out about (depending on the EB's mood at the time) 350-400 volts.  This is what you are seeing on my videos.  Also, supercaps, which I found out about 2 years ago, act like a battery that can charge very fast and hold both volts and mA's (or amps.)  So, I can use the 2 volts from the EB to charge a supercap.  While it is charging, the mA's are building.  When the supercap is fully chasrged, I can run whatever I want from it.
My 650 F cap is due in this week.  I will make more videos showing this approach.  to me, it is no different from solar charging batteries during the day, and running stuff at night from the batteries except, the supercaps charge up fast and are good for millions of cycles.
That sounds like a really good famly connection you have there.  I would be very interested in any informatoin you are able to discover via tis route.
These devices are good, working FE (to me anyway) that need to be explored fully.  Thanks for this post.
jeanna
I took a scope shot of my plain EB today. Dipped zinc spike and probably gold but I dunno-- from a used cellphone. I will resolder later again. It did not want to take the solder.
It still isn't any higher than last year... maybe lower. 0.664v
but
I did manage to take a scopeshot. at 2.5MHz.
Have a look.
jeanna
