0 Members and 28 Guests are viewing this topic.
t3t4
Thanks jenna for the reply,
I know I should keep reading, but either it's the lighting in this room or the LCD monitor I'm using that is honestly causing me blurred vision or blindness as I call it.. Either way, it's not a good situation.
But now that I have a reply, I will continue explaining what it is that I am doing. But first, I'll start with my results. Yes I can light LED's, but more importantly, I can charge or re-charge any battery, even alkaline batteries!
I do this using a thin piece of wire in the sky. It's just the three pack radio shack wire, nothing special. But I run this through a charge/dis-charge circuit which has netted me over 35 volts DC. All it takes is a simple circuit with an aerial and a ground. I'll get into particulars if any are interested, but I live here in the East in PA, so I am 180* different then you jeanna and that's a good thing in terms of location. What you do I can test and vise versa. But this resonance is the key in either case.
I too see about 5 MHZ through my circuit on my scope. All this tells me is that I am still way too far off to extract any real power. I have nothing resonating properly, yet. But it only takes coils and capacitors to make my apparatus function. The same basic devices Tesla had available in his time. I am beginning to experiment with tubes, but these are fragile and burn out easily. It seems strange to me, but when you get close, you burn things up. The power is there, it's real and it can do real damage!
I did not know this was more or less a dead topic. What I do know is from what I have read throughout this entire forum thus far, when playing with the earth or the sky, we're all simply re-discovering Tesla's work. I can certainly understand where some of the conspiracy theories come from. This is all but 200 year old technology, and we're still to this day dead in the water. Enough already!
This system works on a resonant frequency. You don't have to use coils or caps, but you won't get anything that can do more then simply light up LED's. The joule thief is a good beginning, but this is not where it ends!
Keep your rods in the ground, but drive them deeper. Then erect some sort of areal. I did this on my rain gutters because I have an "L" shaped building. Leave one end open and the other end to feed a capacitor via wire or whatever. Attach the opposite end of the capacitor to a diode leading to ground. Then note your results.
I have gained as much as 35vdc doing this simple experiment. It can also be done in the home. Use the water spicket as ground or, modify a power cable for the ground only, then erect some sort of areal within your home. It works always and kicks the crap out of solar, simply because it never ends! This is something I have been playing with for years now. But my math skills are lacking severely. I'm having a hard time learning how to wind a coil that resonates at my desired frequency.
Jeanna, I know you see 5 MHZ or so on your scope, but keep in mind there is math involved here. What you see is only the beginning, and I can verify here in the east that I too see the same thing. Albeit a wave form I have never seen before, until I touch the oscilloscope probe to my head in the temple Reagen. My wife seems to have higher output then I do, but the point is, the wave form remains almost the same! Try it, a scope is an input device, not an output component, so you have no worries. But I'm sure you will see that you are emitting the same basic pattern as the earth.
By this test/measure alone, I have no doubt we are all from earth, and not from the so-called planet X.... :o.... ;D I have tested several people thus far and it would seem that us mere mortals exhibit the same basic wave form as the earth itself. Pretty interesting huh?
Anyway, that's enough for now.
Thanks,
t3t4
t3t4
Oh, one more thing I forgot to mention. you should be using analog scopes and meters, not digital.
t3t4
protonmom
Welcome t3t4!!
First, let me say this is def. NOT a dead topic.  We "newbeez" are just busy reading the other posts and trying to get caught up.  Not just the other posts here in this forum, but also the other forums that deal with the earth battery and earth energy receiver and earth probes...or the joule thief.  At least that is how it is for me.
Is there any way you could post a drawing of how you have your arial set up?  I would much appreciate it.  Thanks.
Have not seen Local Joe around lately.  Joe are you still here?
jeanna
Quote from: t3t4 on August 22, 2009, 04:08:51 AM
t3t4
According to the box, the Velleman personal scope is not a digital scope, just the read-out is digital and being portable makes it much easier and more reliable than using a wall powered scope.
There has been more than one instance of bleed-through from the ac line in the reports of fellow testers. So, pick the walnut with the best pea inside. You have a battery run analog/digital scope that goes outside to the site, or you drag wires out the window and wonder if the 55hz is from the line or if it is real.
My scope readings this year are explaining many unexplainable questions from 2 years ago when I only had a DMM. Anyway. the DMM doesn't even SEE these waves I am talking about.
I tried to use a galvanometer but the swing was very fast and I could not read it. All that is in past posts.
thank you for mentioning this,
@protonmom, did you get your order together ok? I am excited to see what you do when it comes.
jeanna
xee2
@ t3t4
How do you do it? I have tried this many times because others have reported similar results to yours. But every time I try this I only get millivolts. Not even enough to rectify with a diode. Please note, I do not doubt your results. I am just frustrated I can not get similar results. Thank you for sharing your results.
