0 Members and 25 Guests are viewing this topic.
Magluvin
Jeanna
I will check out the rest of the vids.
Im not picking here. =]  Ive just been through it before myself. I thought I was for some fascinating reason able to add more and more light bulbs to my output in parallel and they were all as bright as just 1. I was like Yeee Haw Baby. But I found my bridge was collecting from the battery while it was pulsing the coil and collecting bemf.
This has happened to me a few times in different configs and I find them pretty quick, but man do those experiences stick. I havnt seen the other vids yet, but the only thing I could think as to why it wouldnt take from the first battery is due to the transistor voltage drop? A good bit of my experience was with reeds and there is no drop.
But it has me thinking already before I see.  Ah and plus the bridge drop. Maybe. hmmm. Ive just played with trying to feed back to the first battery quite a bit and the 2 ways I have found successful were to take the bemf to the primary of a transformer, which is a perfect isolator for phase and to lower the high voltage down to a lower voltage above the battery voltage and the current will be more also.
No. 2 way was drive a second and third pulse setup off of the first ones bemf, that has been rectified to a cap that drives the second pulse setup. Then the output of the second setup is back in phase with the first, as in the grounds and positive from the input of the first pulse circuit now can be connected to the output of the second pulse circuit without conflict.  I have yt vids that show this.
But as for charging a second battery, when that second battery is low, that first battery is dumping some current into that bridge when the motor pulse happens. In my experience anyway.  I need to watch them vids, I am always willing to learn something new.  =]
mags
Edit    No 3rd pulse circuit just 2. Im a loon sometimes.  I did do 3 in a row and it works, but the out to in was out of phase again like 1 circuit. I thought of it and tried it thinking that the stages could run in sequence to give each recharge cap some input before it was drained, and I was so wrapped up in the seq thing, that I forgot about the phase, but I found it. lol   So 4 in seq will work and with 2, the 3rd part of a 3 sequence would be an off time.
electricme
@Jeanna,
Quote from: jeanna on February 12, 2010, 08:40:21 PM
I just saw a most wonderful video made of john bedini last year.
freenergyinfo posted it.
http://www.youtube.com/watch?v=0aA8-0tctyw&feature=channel
In it I think I learned what john was alluding to with the electroscope.
It is an effect he describes happening inside the battery itself.
This is really interesting.
John talks about the spikes a lot and has made a method of charging batteries with them.
Jim, I think you discovered the same sort of thing last night.
I am thinking a 1.2v joule thief can indeed charge a 12v battery or 12 of them easily because the spikes don't blow up the battery as amps do, but they cause a charge to appear on the plates that has the same or better effect as a full battery.
(If it is reversed, it can be confusing to an operator, but that is in there too.)
Last year I spent a lot of time testing the ways to use the spikes on multiple secondaries with series inductors. here John shows how to store more than is "possible" in a battery for later use.
Great video john!
5 stars.
jeanna
I also will take a look at this one, John Bedini knows exactly what he is about, it's school time again lol.
I can download, but not upload attatchments, real pain.
Activ8me help wont even answer their help line.
jim
guruji
Hi guys it's true that with spikes by a bedini motor will charge batteries. I did two small wind turbines with small motors like children do. I fed them to a JT/Bedini circuit. When wind blows they're putting around 80v  :D into the bank. Amazing guys and it seems that they are charging my 12v batteries!!!.
Thanks
Doug1
For reasons not worth going into I happened to have stumbled upon the subject of radon. It might have some influence on the earth battery. Others better suited can make the connection. As for health concerns caused by radon ,well sometimes you get the bull sometimes you get the horns. Not knowing dose not exclude you from the effects. It may how ever be in part or in full how NS got the output levels he did. On the down side if your in a area with high levels of the gas you might want to cover your arse with a little bit of reading.
  Even the areas he demo'ed his equipment follow the mapped concentrations. Being energetic the EB may be drawing such a energy source to itself by reducing equalibrium of the gas in the ground after the chemical battery effect has worn off. Im not saying it is dangerous just noting there may be effects not yet considered.
IotaYodi
Quoteupon the subject of radon
At one time I was a  facility manager and had to take tests for every room in the building. Radon may have something to do with the NS coil. Anyone who has an NS coil or EB should buy a radon test kit and see what the ground levels are.
What I know I know!
Its what I don't know that's a problem!
