0 Members and 36 Guests are viewing this topic.
Localjoe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Localjoe
@akash and all of rest of you new to this thread... The reason some of the freq activity has stopped here , well snow in my neck of the woods..and the same in others. Anyways you guys need to read the whole thread we've stumbled across a lot of things here and there all not the same.  as far as our basic earth battery bill has gotten the best results thus far with his graphite rod or carbon i cant remember which  but its here upwards of 1.7 to 1.8 v and a few  milliamp s.   Just two rods, i use a  nice zinc skrew an i mean a quarter inch diam 8 inch long zinc skrew and a peice of quarter inch copper pipe... the cells do work in series and the work better separated further from each other.. As well you need to align them with a compass to magnetic poles read this whole thread and you will see the progress thus far... My intrest lies in single line conductors and earth energy modulation as a carrier base. But i am working hard to devolp a small device for campers that will have abuilt in compass for easy alignment and you just stick it in the ground .. .no bigger than say a 20 soda bottle... with the use of that step circuit i plan to use the 5 v for a usb connector thinking that would be the most versatile thing to make for the socket. It would power either a few led's for a light or a usb socket for ipod/ cell recharging ect.
        Keep the good work comming folks
        Joe
nightlife
Localjoe, I think you need to wrap a magnetic field around you poles while ordering certain frenquencies using a wire wrapped around the magnetic field. I believe once you do that, you will find that you will have much higher readings as well as the cure to all our energy needs.
I believe the ordering will require to be done with pulses.
georgemay
@All,
Is there any place I could buy copper wire insulated with cotton or silk? I know it is antic stuff, but I need it to replicate Stubblefield coil battery as close as possible.
George
akashh
The experiment I had done was actually this:  I filled a couple of flower seeder trays with earth (topsoil) and put copper & zinc (and I think i used copper/aluminium too).  By putting them in series I was able to get 2 V which was enough to light an LED dimly.  I was very happy, but the next day the LED was very dim and the day after it had gone out.
From my own experiments I don't remember being able to get more out of the earth by putting batteries in series, but I'll have to try again.
@localjoe - I have been following the thread from the beginning, and I do recall all the experiments that did go on.  What I was trying to say is that free energy is definitely out there.  However, it may take some more time to find it.  Now, if we already have and can easily duplicate a small earth battery of 10 mA or 20 mA @ 1.2 volts, then we *already* have an application for all the research so far, and we can make a product / gadget that works and can be improved upon.  I'd have done this already but have a broken arm and am unable to go digging/experimenting.
