Pardon
lasersaber you are doing very good work. thanks for sharing.
wintermuteai1 if you are wanting to know if the voltage will double by shorting the inter and outer wires. no it will not, shorting those wires only makes an electromagnet. i hope this answers your questions.
jeanna i am going to rewind the secondary using smaller wire (mag wire). yes the bridge rectifier is the way to go. you really dont know how many times i have wished i had a scope.
i think at this point for my small coil i will build a charge pump and give that a try. to see if i can get any usable voltage. also i may need to invest in a  new meter. mine was freeking out last night and that meens i have blown something inside of it. i am only on my 6th or 7th meter. i was spiking my coil and checking amp output and i left it connected to long. but my last reading was 267.4 mamps. i was spiking the coil with a smaller version of the imhotep relay charger. with the relay charger i can spike it for 24 hours using 4 volts or less on battery power
jeanna
Quote from: Pardon on March 25, 2010, 12:03:03 AM
267.4mA is pretty darn good, and 24 hours is great. How noisy is the smaller version of the imhotep charger?
I got a hand held scope from velleman for $190.00.
It works very well.
I would stay away from using any meter with the spark discharges from the imhotep or tesla disruptive discharges.
I am sure they are too much and too wild for transistors and IC's.
I have seen where lidmotor uses a filament bulb to show that there is a certain amount of mA and to keep the rest of the components safe at the same time.
I am sorry I don't have a link exactly.
@all,
I just ordered some of that cotton covered copper wire!!!
Also today, I used the reed switch which is part of the radio shack reed relay. I checked it with the resistance part of my meter, and when a snake egg magnet OR a neo magnet got to within an inch of the reed switch the meter registered 0.3 ohms... so, this means the switch was thrown at about an inch.
Now, I just need to make the little motor.
Also,
I got notice that the "simple motor" has been shipped so hopefully it will give me the motor set-up and I can substitute a NS coil for the one in the kit.
This seems to be the best way for me, since I do not own a lathe or a drill press or a table saw.
thank you,
jeanna
electricme
@IotaYodi,
Very true
Quote from: IotaYodi on March 24, 2010, 12:58:40 PM
Standard "hot" A for sure. But if the NS coil is using "cold" electricity as some suspect it may be possible to run larger currents in smaller wires without heating up the wires. Wont know that till there is a working prototype. It would be outstanding if we could even get a JT to work with it. Remote locations could have at least light then.
I havent seen "cold" electricity, that dosent mean it's not there, I hope it is, then we can take a look at it working.
I have heard "cold" power gets its name from the frost which forms on devices under a load, I'm eager to see this one day   :D
jim
IotaYodi
Floyd Sweets work verified cold electricity. He was a brilliant electrical engineer and a graduate of MIT. He created the Vta also known as the Phase-Conjugated Vacuum Triode
"Phase-Conjugated Vacuum Triode. This device produces negative energy which
is the reverse of the conventional positive energy generated by all devices in service today. The arc generated by a short-circuit in a negative energy system is excessively bright and cold,producing barely an audible hiss with no explosive force. Melting of conductors does not occur and this type of negative current passes through the human body with only the feeling of a chill.
Conductors remain cool under load while only tiny cross-sectional areas of copper are required to convey many hundreds of watts of power. Although all of this seems nearly unbelievable,only what has been demonstrated in the laboratory has been described in this paper. The source of energy is unlimited,the virtual vacuum of space itself structured by a motional
electromagnetic field is the powerhouse"
What I know I know!
Its what I don't know that's a problem!
the_big_m_in_ok
Quote from: IotaYodi on March 25, 2010, 10:55:04 AM
"Phase-Conjugated Vacuum Triode. This device produces negative A which is the reverse of the conventional positive energy generated by all devices in service today. The arc generated by a short-circuit in a negative energy system is excessively bright and cold,producing barely an audible hiss with no explosive force. ...  Conductors remain cool under load while only tiny cross-sectional areas of copper are required to convey many hundreds of watts of power. ...
Question?
Could this aspect of electrical physics be related to the "Tesla Hairpin" circuit videos?
http://www.youtube.com/watch?v=HXLnAtBqMzY&feature=related
http://www.youtube.com/watch?v=AvCZG5ccPsk&feature=related
--Lee
