Bruce_TPU
Quote from: alchemist123 on May 22, 2010, 06:40:42 AM
You missed what i was trying to say, you cant combine dc and ac power sources they are different kinds of electrical current.  And rectification drains power.
You can if AC is turned into DC.  AS explained above, even if there are losses, which there will be, it will not matter!  We are only looking for a SMALL PERCENTAGE of flux increase onto the secondary at each pass.  Why is this so hard to understand?
You are discounting the natural losses that occur with each coupling,  namely heat losses.   This device is far from overunity.  Heat generated by a conductor is equal to square of the current if i remember right.   Its an induction coil, plain and simple.  The steady dc current is supplied by the  voltaic couple wrapped around the core body a means of switching produces pulsed dc inducing a current every make and break into the secondary of high frequency high voltage ac characteristics.
This forum is called "OVERUNITY.com" in case you missed what forum you recently signed up on.  Many on this forum believe that the ORIGINAL NS was more than just a galvanic battery.  The original(s) produced far more than they should have just using galvanic reaction.  Can you say that you have tried feeding back a NS coil, while it is buried in the ground?  Until then, I do not believe you can say that it doesn't work.  As was pointed out to you this is not a plain induction coil.  I have already explained that only a tiny, small percentage is needed in increase for it to work.  I have "discounted" nothing.
It is an EASY enough experiment for anyone with a working Lasersaber type coil to attempt.
Localjoe
Alchmist .. be nice bruces has been around for a while
.. Wasent the juice off the primary .. pulsed dc as I remember....  go take a meter to a dc  it shows ac just at an extreemly low cycle.   Id be willing to say that with the proper tuning Bruce may be right .. Remember one of the key observations at the time was this thing took a lil while to prime and when it did folks noticed beautiful sparks........... beautiful sparks dont come from low voltage dc  hense me thinking that the "self generating induction coil " may hold a bit more secrets than youd like to admit.. Id call free high frequency high voltage  overunity if were not leeching random em waves and that isnt the case here..
Also theres a whole range of lights and other devices that run on hf hv if configured properly.... BIG FLORESCENT LIGHTS>..
Lets just say we get this completed with  some usable power .... whoes to say it wont power a garage full of florescent lights or maybet we could pair an inductive motor to work with it like a few of teslas designs.   There are still a lot of overunity possibilities with this device
So to conclude .. " CREATIVE AMPLIFICATION" Is still a viable route to travel with this device and experiment .. and i dont mean the finger painting kind of creativity.. waves add to each other as to prodcue a more powerful one...  That was the reason for my whole rlc resonance rant before....
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
IotaYodi
Quotebeautiful sparks dont come from low voltage dc
Never heard of sparks being beautiful before.  ;D
You can get visible sparks off a 9 volt battery. You can also have invisible "sparks" or current that isnt hot enough to ionize the air to make it visible. Whats strange to me is that a low voltage spark creates a more intense magnetic field than a higher voltage spark.
What I know I know!
Its what I don't know that's a problem!
Pirate88179
What I don't get is that folks keep saying this is not an overunity device.  Well, consider that:
Input=0
Output=>0
How is this not ou?  Even my simple electrode circuit outside, which is still working, is ou.  My input is 0 and my output is enough to light 400 leds or some big floro tubes.
I don't want to argue on what the definition of OU is but to me, anything that you have 0 input and get >0 output has to be ou in its most fundamental form.
conradelektro
QuoteBill (Pirate88179) wrote: Even my simple electrode circuit outside, which is still working, is ou.  My input is 0 and my output is enough to light 400 leds or some big floro tubes.
Bill, does your "simple electrode" corode? And if it does not corode, you could pick up some induction from a near by power line. It is difficult to get away far enough from power lines near a house or in a settlement.
If I connect my multimeter to a good "ground" (like any metal water tube in the house) and hold up the other wire in the air, I measure 0,8 to 1,2 Volt AC (the electromagnetic noise from Radio, TV, cellular phone towers and heavy duty power lines).
I always wanted to know whether the wires in a Stubblefield coil corode?
Conventional theory says: the electrodes corode (give away stuff to the electrolyte) and such provide the energy for the production of an electric current. The electrolyte in the ground and in the Stubblefield coil would be water (and some salts in it).
Greetings, Conrad
