Bruce_TPU
Quote from: alchemist123 on May 23, 2010, 02:08:21 AM
Remember what Tesla said of Edison
"His method was inefficient in the extreme, for an immense ground had to be covered to get anything at all unless blind chance intervened and, at first, I was almost a sorry witness of his doings, knowing that just a little theory and calculation would have saved him 90 percent of the labor. But he had a veritable contempt for book learning and mathematical knowledge, trusting himself entirely to his inventor's instinct and practical American sense."
Remember what I said of the following, "Edison is a long time dead and buried, and yet we remember his inventions that have improved all of our lives.  What will you be remembered for?? Book learning is AWESOME, but it depends,  WHICH BOOKS!!  I have read nearly all of the Greats, legends both recent and distant, and their writings, including Einstein.  If I recall, Einstein wasn't too hip on the common conception of gravity, and came up with a mathematical formula to prove the gravity was a curvature of time and space.  This idea first came to him while looking at a man on a ladder, outside of his window.  Imagine that, ideas through observation.  And then he spent MUCH time finding an astronomer with the proper equiptment to prove out his theory, because he did not have the skills himself."
So, Alchemist123, what will you be remembered for?  Besides trying to discourage a SIMPLE experiment?  It makes me wonder who you are and why you are even here?  What are you worried about if it isn't going to work and of course you know this because you read it in a book.  LOL  If you think that mankind's sum of knowledge is contained in what we know, that is laughable!  In the '70's Nixon nearly shut down the patent office because it was thought that everything that could be invented had been.  How arrogant.  How egotistical.  Knowledge is doubling at unprecedented rates.
I will not let you or others like you discourage others from experimenting, hands on with something you or a book say can not be done!!
If we listened to them, Overunity is impossible, there is no new energy sources, or untapped old ones, so why are we even here?  We should all give up if we followed your logic.  But we are here for new discovery.
P.S.  Also there is a LOT to be said for "American Sense"!
@ ALL
Please see the Pseudo closed loop circuit that Aaron posted at Energetic forum for those with working Lasersaber type coils to experiment with!
Aaron wrote the following:
"Both windings wound in same direction. North at (top - left in pic) of coil
when plus is at same side when switch closes. Can everyone see what is
happening here? It can decrease front side battery draw by 50% easily."
Have a good day,
Bruce
alchemist123
Quote from: flathunter on May 23, 2010, 07:31:46 AM
Doesnt really matter if its OU, or not OU pirate - as long as we're not paying for the elecy, right  ;)
I'm pleased your earth battery powered JT is still going strong.  Keep up the good work.   ;D
Couldnt have been said better
alchemist123
Quote from: Bruce_TPU on May 23, 2010, 09:07:51 AM
@ ALL
Have a good day,
Bruce
Your Ad hominem attacks are funny to say the least.   You have not once provided any proof that your idea will work,  and still have yet to describe  how it could possibly overcome  I^2 x R  losses.
I am skeptical, but i have never deterred anyone from experimenting with your idea.       I hate seeing modern day Keelys however claiming impossible things from science with no evidence backing up their claims,  delusional at the least dangerous at the worst.
flathunter
Quote from: alchemist123 on May 23, 2010, 10:01:59 AM
This is a silly argument and its getting out of hand unnecessarily.  Bruce is a builder.  Alchemist is a builder.  There are lots of builders here - even i build when ive got the time.
Lets let our builds do the talking eh?
Now, back on topic!   :D
electricme
@all,
I had a little chuckle to myself about the below beautiful sparks, he he  :D.
Quote from: IotaYodi on May 22, 2010, 12:46:05 PM
Never heard of sparks being beautiful before.  ;D
You can get visible sparks off a 9 volt battery. You can also have invisible "sparks" or current that isnt hot enough to ionize the air to make it visible. Whats strange to me is that a low voltage spark creates a more intense magnetic field than a higher voltage spark.
Actually, if anyone has the skills and wants to try this, it will show you just how much energy is avaliable in low voltage.
Remove the secondary HI Voltage windings of a MOT, then rewind just the secondary with 3 turns of starter motor cable.
Then if you are game, short out those 3 turns, ha ha, this will show you just how much mega jewels are making beaudifulsparks ;D.
jim
