Mk1
Quote from: IotaYodi on May 28, 2010, 11:32:41 AM
Lidmotor,dragon and others are reporting there coils last only for a day or two. Lidmotor found his zinc coating ate up after only one day.
That part is wrong , i have been trying to tell you guys for days , you need to put pressure on the coil if it goes down ...
I hope some will listen to me if not listen to lidmotor , look at his movie until the end ...
Mark
Cap-Z-ro
Don't listen to a word Mark says!
Listen to me instead.
Mark really does know what he's talking about, take him seriously!
Regards...
IotaYodi
QuoteThat part is wrong , i have been trying to tell you guys for days , you need to put pressure on the coil if it goes down
Mk I agree with that. Ns even stated it. But thats not wrong. This is what they have said. Even with pressure though I dont see what that has to do with lidmotors zinc being destroyed.
To add to this. The windings should be uniform and lined up and when you add the pressure the coil windings are evenly distributed.
What I know I know!
Its what I don't know that's a problem!
Mk1
@IotaYodi
The battery did not stop because the zinc got destroyed , it will work with and without zinc ...
The issue is if a layer of zinc , get dissolved the wire is then smaller , therefore need pressure ...
Telling people about the zinc , will only confused them and is not the issue , regardless of what anyone had said in the pass.
Promoting that info is wrong , i had to say it.
lasersaber
Hi, Mk1
I agree with you about the zinc on the wire not being a problem.  Aluminum wire will get brittle very quickly so I do not recommend it.   Pressing the coil is an interesting idea.
I'm on the verge of a possible major breakthrough with the coil I made in my last YouTube videos.  I am testing it now and so far it seems to be working but it will take about a week of constant running before I know for sure.  I will keep you all posted.
