jeanna
On my way out to move the probe but first:
I hit the neg side of my super cap and left the pos side open to the air. then attached the cap to the light/resistor again and there is light.
Yes, I checked this first by hooking up the light without charging the cap to make sure there was no recharge on the cap and the light was off .
I did this again outside and it didn't work and then again inside and it didn't work again. I will try again I just want to report this right away. arrgh
I got this idea while reading Bill Beaty's stuff.    So, it worked - weakly.
I guess it won't matter if we are using earth power but Tom Bearden makes a nice description of how to not use up the power in a battery by separating the fill stage from the use stage of a power set up. This is how he sets up his circuits. but his circuits are still over my head. (but I am getting taller every day ;D)
Bill,
Did you ever read Bill Beaty's description of how a cap works? his site is http.amasci.com. His site takes weeks to read it is so big. also good site. but the page about caps is especially useful, I think.  If that link doesn't work tell me I go and find the right spelling.
jeanna
Localjoe
@bill
            nahh it shouldn't dissipate that bad bill ive taken readings off the cap before. In the coilgun i made i just put a momentary switch off - on cap leg, connect the coil on one side of the switch and the other leg of the coil to the + on the cap. when the button gets hit it dumps the current through the coil. So being that i can charge it and let it sit for a min or so i i think it shouldnt dissapate that quick.
        joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
jeanna
Quote from: Localjoe on December 21, 2007, 03:49:49 PM
@bill
        joe
joe
It isn't a battery is the reason. It is pure charge. There are no chemicals to be made or broken down for the intake or outflow of charge on a cap.  (T-RC)
And the charge will last in there for a really long time, but as soon as it is hit it dumps 66% of its charge in 1 time constant and is nearly gone in 5 time constants.
Can someone help explain time constants?
jeanna
jeanna
Brrr! Its cold outside
So, with frozen fingers I have some more results.
This time I checked for the strongest alignment by using the Cu pipe from yesterday and moving the magnesium block around then put everything on that axis. Plus I did some control type elements.
Cu/Cu 0.047v
Cu/cement  0.179v  then I looked again and it had gone to zero so I did it again
Cu.cement  0.264==-->0.15v and still dropping
Cu/Mg  1.232v
Cu/Zn   1.003v
Graphite/Zn  1.020v
Graphite/Mg  1.189v but the mg block was getting dirty so I held the probe hard in place and got
Graphite/Mg   1.388v
all voltages held steady except for the one with cement.
I am intrigued by Stefan's Idea to put the powder onto some material and make a compressed material in the shape of a rod.  Is anyone else intrigued by this? Is there a way to make a longer rod.
jeanna
Localjoe
@jenna
If i remember right when a cap dumps its load there may be a time constant created by the ESR of the circuit, Its a fun concept to get used to and i dont fully understand it but think of a sharp increase that can only go so high until a on off cycle or bounce back was completed to let  the remainder through it may create a phase differencial because its going through the resistor which slows the second output by 90 degrees.
        Joe
PS- Thanks for weathering it i would be if every stupid part of my lawn wasen't covered
