fathershand
Tishatang, when you built this device, how many volts and amps did you get and was it continuous?  Also, how many volts and amps did you apply to the secondary to "prime the pump"?  Was it AC or DC?
Thanks
Tony
MW383
Iota,
Yes I am well familiar with Tishitang's writings and diagrams here. He seemed to be working from the premise of running the Iron and Copper windings of the primary at a resonant frequency. I'm in full approval of the concept. I am operating my newest coil different. I am not running my primary this way. I am instead interested in running the secondary coil in the fashion Tishitang suggests. I am pulling a strong magentic field through the primary coil by using my secondary. Works like a charm. The primary is just sitting there while this happens. This is where the fun is beginning. I am observing very interesting things. Very interesting in fact. Far more interesting than my former coils where I used the primary to create the magnetic field. This new way has the options we need. Options that get shut when we use the primary for field generation. I do not care what the patent says, it was modified to satisfy some government loving patent office bozos. Smart bozos that were working an economic situation. In other words, you cannot have a population operating a free energy source. Screw this. I will run the thing backwards to the patent and get the bugger doing what it is supposed to. Think of the process I propose. It is different than the typically cruddy primary inducing a current into a secondary. It will simply never develop the power to perform the work Stubblefield describes. Never. The 'mechanism' only works one way. Stubblefield called it an energy reciever or whatever. I call it an electron pump. I am no OU believer. Stubblefield is not OU. He merely pulled things into his system from an outside domain. That is why this thing will work. It is also why it was trashed by the patent office. Well no more. Think backwards. Rebuild what you have and throw away the idiotic concept of pulling big power off a secondary. :) It's in the iron. The iron is the lever of the electron pump.
Happy building! For me I am nearing the next benchtop phase of testing. A wetted cell. After this it is in the ground it will go. where it belongs.... The only other way this thing will work in air is to employ an air based electron supply source. Of which Stubblefield seemed to have figured out with some of his other designs......
fathershand
I'm really interested in hearing what happens after it is in the ground.
IotaYodi
QuoteTishatang, when you built this device
I dont believe he built it Tony. He knew how coils worked and all about resonance.
QuoteThe iron is the lever of the electron pump
Thats what I see. The alternating magnetic field collapse drawing the current in by standard convention via the south magnetic pole. Questions were raised as how to orientate the coil in the ground as to horizontal or vertical. It may be better to align and angle it / towards the incoming Earths magnetic south pole or geographic north if its possible. That way it hits the very end of the coil broadside keeping this flow generally in one direction. I guess you could attach an iron wire/wires to the end of the coil that sticks out above ground.  Then possibly adding wire,copper/iron?  to that to go vertically to trees or antenna for the electrostatic field or other electromagnetic waves.. I would think this would use the potential difference of the Earth to the atmosphere.
Some questions for you. I assume you wrapped a secondary around the bifilar primary? Can you do a simple hookup pic? I see your in the States. How much did you pay for the pw from England?
What I know I know!
Its what I don't know that's a problem!
MW383
Iota,
Angled ground orientation makes sense. I think however that this thing is relatively forgiving in these orientation regards. I will attempt drawing a diagram that outlines the system I am proposing. I created what I call a quasi-bifilar inner coil using the standard copper and iron materials. On top of this is an outer coil comprised of copper that is bifilar in a purer sense. There will obviously be external devices attached to this double coil arrangement. I am revising Tishitang's concepts slightly because from connection and theory of operation standpoints, my coil is a bit different despite looking nearly identical to all of the other coils people are making.
The basic principle is to bring in a flow of electrons from the outside world and through a unique process, attach them into the internal world of the Stubblefield device. If we have frequencies involved, 'earth' should make a response to our little electro/magnetic intrusion. The response will be one that seeks to equilibrate but at the same time it will have interesting characteristics. It will be initially larger then taper off. In a one shot process, it is just like throwing a stone into water from a resulting wave action standpoint. Only in this case, the waves will progressively get smaller until the water is calm again. (I borrowed this example from somebody, I just can't remember who at the moment). In the case of our 'Stubblefield earth intrusion', we merely keep throwing stones in the water. There are optimal frequencies involved here that will keep earth reactive wave heights at their highest. Here is where Tishitang's theories come into play.
The Stubblefield will work in two modes. One, it will piss off the natural system. Two, it will recieve the natural systems reaction. The idea is to capture the excess portion of the earth reaction. That is the differential we need to create, maintain, and harvest from. No differential, then no real game. What we piss the system off with has to be smaller than the earth response. There are many optimizations that can be done to improve this. Many of these already discussed on this forum.
