0 Members and 735 Guests are viewing this topic.
hansvonlieven
This one was done with MS paint. I find it is very good for basic graphics, when it gets beyond what it can do I use Paint Shop Pro.
Hans
nightlife
Pirate88179, thank you for keeping your words kind and I was only trying to get some of you to reason with common sense to help steer everyone in the right direction. Hans seems to have the concept for the most part and I was replying to a post he left here.
Since you were so kind, I will do you all a favor that is working on this earth battery theory and that is to tell you all that you must use 2 sets post, 2 Zinc and 2 copper. The first sets copper will have to have one lead attached to the other sets zinc and the first sets zinc will have to have a lead attached to that to be the ground. The other sets copper post will be the positive.
            1st set of post
copper (positive)   zinc (to second sets copper)
            2nd set of post
copper (to first sets zinc)    zinc (negative)
Not sure how much power it will create but the do sell kits to build these to run clocks using two flower pots as the power source and you can buy them at Hobby Lobby for about $20.00
As for my theory, I am again sorry to aggravate you all but as I said, you must rely on common sense when dealing with things that no one as ever seen. Most here want to think of a electron as a solid but yet wants to think it can go through brick walls. Then we have everyone here wanting to make electricity or some other form of energy but then they don?t want to start with the basics and find out what energy is. I started several threads to try and get you people to open your minds and let some common sense take over to help you all achieve your goals. Big money has painted the picture most of you have in your heads and I am just trying to get you all to understand that you cant always believe what you read or even what you have been taught because believe it or not, big money controls what you can be taught as well as most of what you read.
Just think about that and I will from now on post drawings of my ideas now that Hans has explained to me how I can post them. I just started a Youtube account so the I can do some experiments and video record them and post them for all to see. I again am not here to piss anyone off but at the same time I am not here to waste my time with ignorance. When I first started I explained to you all that I am a mechanical problem solver by trade. I solve problems that people with years of schooling could not. I achieve my goals by using common sense. I know this is a far cry from what I am used to but I am getting to know what is going on and what is needed to solve our problems with this particular situation.
Good day to you and I wish everyone happy holidays.
hansvonlieven
G'day nightlife,
You are talking here about a simple galvanic cell which is what they use in flowerpots. This is NOT what we are talking about here though. We appear to be dealing with a totally different phenomenon here though there will always be some sort of galvanic action as a component.
Galvanic action is independent of alignment. What we are doing apparently is not. That should be enough to raise eyebrows, alas not many seem to grasp the significance of this.
Hans von Lieven
jeanna
Quote from: nightlife on December 22, 2007, 10:21:51 PM
            1st set of post
            2nd set of post
Nitelife,
We had a link a couple of weeks ago to theverylastpageoftheinternet.com (Don Adsitt's site) where an extensive array is proposed to produce 120 volts by doing something like your suggestion using 120 copper tubes arranged 12across x 10deep. each copper tube had a zinc nail inside it with earth inside the copper tube, all buried in the earth with a few other details.
I just put a couple of pieces together which I hope will hold up long enough to try this outside the next time the rain stops. I will only be using 2 or maybe 3 sets of copper pipe with zinc inside wired in series like this. I expect to see about 3 volts if it works.
The last time I did this I got zero volts from the combination where I had had around 1 volt from a single cell. I wanted to check it out again being more careful this time and following those details more carefully.
we'll see I bought the torch but I have never soldered using a torch before. It should be easy enough, but we'll see. I will of course report any results here.
Stay tuned.
jeanna
nightlife
jeanna, I cant wait to hear about your results. I personally will be testing a few things after the holidays. Good luck to you and all and I do hope everyone has a fun filled holiday season.
