0 Members and 16 Guests are viewing this topic.
gadgetmall
Quote from: Pirate88179 on April 10, 2009, 01:15:12 PM
Wow, can I ask for your source of the mag. rod?  Also, how much?  I have not been successful in finding a company that would sell me just one.  Thank you and, good luck!  That rod with the carbon will give you great mA's I am sure.
Bill
Bill I have plenty of them and a local source for the carbon and Magnesium . i sell them as an earth battery kit for 55 dollars +freight  they are 1/2 inch diameter and 12 inches long . about a pound of magnesium .
Gadget
UKpirate3000
Hi All, Apologies if I’m a bit of subject, I tried posting as new topic, prob wrong place!, this is my second post on this fascinating site recommended by a regular contributor.
I live on a boat in the UK I run mostly 12 volt systems. The water Pump a Par max 4  model 31620-0292 keep failing, they don’t seem to burn out just stop working. My system consists of 6 Hawker powersafe 12v105f (105amp) power cells a silverline cb20-1 charger set to min 12a. This is charged to a stephill generator putting 220volts of fairly stable modified sine wave power, run for on average 2.5 hours a day. The max draw of the pump is 6amp at 10PSI and fuse rated at 10 amp. I think I need a put a 10 amp Diode in line on the positive, do you think this solve the problem? If so and ideas where I could buy one in the UK I’ve looked on line but to be honest, always best I find, I’m not sure what type of diode I need. Any advice with problem or potential suppliers would be greatly appreciated.
gadgetmall
Hi all
    OK here is the latest Graph from Alternative Systems Research In the Black Mountains of NC .  Showing that the last Graph was not a mistake . The Test was done over and over to be sure the Doused Magnetic Meridian Ley Line's are giving More Power than not !!!! Well its looks like Greg At ASRF has proved that indeed you will get more voltage from rods in the Ley lines .. Stubblefield rediscovered . Now its a matter of Converting that power to storage and then using a JT to run 1000 leds  ;) I am also curious as to wheather mass of the electrodes have anything to do with Power . I am going to bury a Magnesium car rim and find out later this week in comparison to a 12 inch magnesium rod .. I will also find out how far apart are the Ley line's  10 feet 20 50 100 200 whatever . Happy EARTH DAY
Gadget
nightshade
Hi all thought I would add somethink interesting iv found out
about my earth battery setup. using four sets of roofing iron
and copper pipes had my jule thief running with four white leds.
the weeds around the setup were turning into a jungle so
thought id do a bit of gardning i wish i had not now after
pulling those weeds the out put on my earth battery dropped
from a nice 0.95 volts to only 0.88 and the jule thief stopped
working so from now on ill just let those weeds grow ha ha
i will add another set of plates and see if the volts go up again
crossing my fingers back this way one good thing though the
little circuit out of my solar garden light still goes nice and
bright dosent need as much juice.
kukulcangod
I find your observation of the outmost importance , for I have the same discoveries in our small garden the more plants my wife grow and place in it the more energy is harvested , say a planter where my rod was lost power as I put it away from the garden then again to rise up at its proximity and the cluster of flowers, also the planter has been on on concrete the whole time now its "planted" on the very same ground as the plants giving me this time a stronger current and voltage on the order of 2.035 volts and 1.03 ma ...still can't make a joule thief work, still trying to find out what winding size and so forth will make it for me . ???
