electricme
@Gadget
I have only just realised you posted some words for me here, sorry mate.
Quote from: gadgetmall on June 05, 2009, 03:07:16 PM
@all
Actually there are many Ac signals mixed up in a good earth battery as logged by Greg at arsf  . The most can be picked up at 20 feet apart . carbon to the north . In a Magnetic LEY line . Ley Lins are about 10 feet apart and move thru out the day .If you can Make a Dousing rod from some stiff copper wire and fin water you have hit a ley line . Water Follows the Magnetic Ley .
Bill you got a good one there . Is your Carbon north ? I bet it is .
I have carbon and magnisium rods of all sizes now here is a picture of a few .This is pure carbon in the first two pics and made just for me and you .
@Jim / Yea ! You see the Magnetic Flux Increase and light a powerfull led . that is something . My 1 Watter i just got won't light at all . it takes over 3 volts :( . Thats fantastic Flux you got there .I wish you had a logger so you see when it repeats , It also might have something to do with solar flares shifting our magnetic Ley . Cool . have you Buried that rim ? I am trying to cut the tire off mine . I came it sweating like a pig drenched . can't take it no more today . I did move My rods and looked at the Magnesium and see how much it ate up . a tiny bit on the end .  i reset the rods again and got 1.7 volts at 5 ma today so far . . I am using a germanium diode now to test the charge on the ultra cap . Also when you get telluric current less degradation occurs on the magnesium or negative electrode  you have to have Two Dissimilar Metals to see any good voltage and the deeper you go the more you see .
Albert
Thanks Albert, you have some good shops in USA, a lot more to pick from than here.
OK I been reading what you have said here, and taking it all in, your right I need a drum recorder, to have some thing I can sink my teeth into, not just theory, I need a drum recorder, setup for a week, and record the amplitudes/waves, mabe a preamp connected to a set of rods will suffice for the pickup, and pass the output into a amplifier, to drive a solonoid on a BIC pen attatched to a rod, and a drum which makes 1 RPM in 24 hrs.
I havent burried the rims yet, tooo much hard yakka, itl get done when I get fed up enough lol.
OK this is for the boffins, I had another idea, grief said someone.
I'm sitting here and thinking about something you mentioned,you pulled your magnesium rod and seen it had a little bit missing, welllll find a small anode that is more sensitive to corrosion, and attatch that to the bottom of the Magnesium rod.
Tomorrow I'll try that water dowsing thingy.
jim
People who succeed with the impossible are mocked by those who say it cannot be done.
Pirate88179
Jim:
Thanks for your kind words on my latest video.  Yes, I have 2 10 farad sc's.  I can short them, and place one on the EB and it will be fully charged in less than an hour.  I have hooked them in parallel to increase amps and series to increase voltage, either way works fine.  That why I used them in parallel when I ran the Fuji the first time.  I did not want higher volts as that might fry the Fuji so, I need more grunt and got it.
I have to say those 10F caps which I used to think were huge storage devices, now seem like small toys compared to Gadget's 650F cap I am playing with now.  I hope you can get one of these sometime Jim.
Thanks again for watching my videos and commenting.  I really do appreciate that.
Bill
xee2
@ Pirate88179
Have you run a test where you completely discharge the 640 F cap and the see how fast the earth battery can recharge it to 1 or 2 volts?
I find it hard to believe that your EB is providing enough power to charge such a big cap in a few days.
Pirate88179
Xee2:
A few days?  This cap will charge up in a matter of hours, not days.  Yes, that is from shorted out 0 energy in the cap.  My guess from what I have seen is maybe 6 hours, give or take.  I will look into this more and post the result where I actually time it.
Bill
Thaelin
Pirate:
   On that camera, could you give me some specs as to its brand and model. I am impressed with the output. I bought one and it looks like I am filming from the back woods somewhere its so far away. Cant do a close up for squat.
thay
