0 Members and 28 Guests are viewing this topic.
john_bedini
Pirate,
Yes I have seen everything you have posted, I know what you have built and commend you for the work you put into it along with all the others.
The thing that concerns me is the experimental work with LaserSaber since he does not talk much. But I have built the same motors for 30+ years with these coils. It is very important in one of his videos in witch he called it the Mag Tap, that is very important.
That indicates if the probes are not causing it that it is possible to split magnetic current in a bar of steel. If you can do this why would you ever need any rotating device. You would just split the streams and charge any battery. I do not trust the probes unless everything is the same metal. but I think you get the point.
His work is excellent because he has the patience it seems to do everything very careful. I want to know if you were successful in building his motor before I say anything about that? My background is in semiconductors and Power Amplifiers as I was trained by the man that invented the first silicon Amplifier ( The Sharma circuit), he is the one that took time with me at an early age. After that the military took over. If I have seen this right then I know I was right with the monopole Motor as that is an open system.
Floyd Sweet also took time with me in Magnetic Amplifiers so I know what that system is. Now comes the TPU what do you think that is, That man was also an Amplifier guy from what I understand. The Joule Thief pops up also a monopole circuit closed looped every once of current sucked from the battery and nothing returned to the system. In all of this I can understand what Omnibus is saying as the science is not presented right to make any sense. I'm not here to disrupt anything just to ask some questions of the experimental results.
I think the work that you have presented is excellent along with Johnny D, Jeanna and others. I make it my business to keep Investigating every form of science with an open mind, I want to know what makes the clock tic.
Thank you for your comment.
John B
shylo
Hi Pirate ,I'm loading video now ,it is 5+ mins long which will take ~6hours to load on my system ,which will probably get booted before it's done.Would it be possible to get a schematic of the circut . I don't need the EB just the circut , plus why do you have a 9 volt battery in the mix, also a pic of the cap you used? If it is not too much to ask I would greatly appreciate it ......thanx ....shylo
Pirate88179
9 volt battery was being charged.  I read it is not good to run these without charging something...when i disconnect it in the video...the 90 volt neon bulb comes on but I forgot to mention it.  The schmatics for this are over on Jonnydavros topic "One magnet no bearing Bedini motor" topic area.
Bill
LightRider
Quote from: john_bedini on January 08, 2011, 06:04:50 PM
Pirate,
John B
Mag Tap possible answer :
What do you think of this movie as an explanation of the phenomenon? (to watch til the end)
http://www.youtube.com/watch?v=AcRCgyComEw
(from youtube: ibpointless2)
LightRider
john_bedini
Lightrider,
That is right good find. So if one would use this hall device with the Stubblefield coil what could you do with that coil? I see it as you could make a self oscillating power source, small at first but it could be done and it would be self powered. But I'm going to wait until Pirate answers my question about the Stubblefield motor, or have you reproduced it? I can see that he does get good experimental results with his devices. So my question to anybody here is did they get LaserSaber's motor reproduced and is it working like his?.
John B
