FreeEnergy
Quote from: Pirate88179 on February 13, 2008, 11:39:02 PM
@ All:
Below is copied and pasted from 2 responses to my earth battery video on youtube.  I think we ought to try this as well sometime.  It is similar to what Joe did a while back but, I didn't know the battery would not run down.  This appears similar to the effects seen on the micro tpu topic.  What do you all think?  I invited him to join us in our efforts over here.
Hey bill if you hook any Battery to the earth batt. and hook a light not an LED. it will burn and not run the battery down as long as it is hooked to the earth battery.tesla new this I bet! I just had to tell you what I learned from you aaaand stumbling across this phenomenom ! Thanx Again! Go Earth Power! Take what you need and the earth will replace it.
uncleshorty (1 hour ago) Show Hide Marked as spam
0 Poor comment Good comment
Reply | Remove | Block User | Spam
Hey Bill I put copper plates in the ground 20ft. 1/2in. copper wire 24ft.long run south then I plundged a 3ft long 4in aluminum pipe into the earth only2ft.deep. I then placed a 12volt batt.between the pipe and the end of the wire.between the +batt and the pipe A sm. elec. motor the same between the -batt. and the copper wire. both motors spin. I then hooked up three 12v. lights to the battery still 12.5 v. Its like pumpig out a boat with a big hole in it the battery is a cap. equal reaction US
Bill
thanks for the info!  :o
Bruce_TPU
Morning all,
OK, that Post of Bill's is pause to stop and think for a moment.  So it would seem that both of these guys took the original experiments to new heights, eh?
They placed a rechargeable battery in their circuit with regular lights, and the batteries remained charged.  If true, then the original earth battery only provided a small amount of power by itself, but when connected with a rechargeable battery to a load, the circuit acts as an electron pump from earth to battery.  Is that what it sounds like to the rest of y'all??   :o
I wonder if these will work out to be the same?  Much easier than our old way.  We must remember to try a rechargeable battery and regular lights in our circuit with these coils.
Cheers,
Bruce
EDIT:
Does my drawing below look correct as to what was described?
Localjoe
@ Bruce Hans or anyone else that can answer this one
Quick question - i turned my relay into a step up transformer/ boost ciruit and i dont know how i did it.  Great right.. anyways i took a signal diode 1n914 lo loss connected to the lead at the bottom of the relay coil going to the arm that vibrates.  The other side of the diode goes to the plus side of a 200v cap from a disposable camera. - on the cap to - battery.  The effect becomes more prononunced when the spark becomes more visable at the contact point. it charges the cap to 60v in about 2 seconds i repeatedly arc'ed it with a skrew driver to see the time it would take to swing up again i was mildly amazed, It was next to instant.. make a long story short the skrew driver was arc welded to the cap by the end of the night and i tore the legs out so then i went and got a bank of 3 of those caps wired in parallel 200v 980 mfd total and boy that sounds like a freaking gun shot.  figured id share  :) i was operating my relay with half dead doubll a's just 2 so 3v or a lil less they were on there way out.
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Localjoe
Here this is folks deff worth some side investigation .. one thought was once that cap fills enough to dump that into a pimary coil at a sync rate and see what kind of results were to be had on a secondary.. Two rehostats are needed to tune but if you got the relay firing fast enoguh to charge the cap in a second or less. im almost there limited by physical matierals, you could then fire the cap  much quicker into a transformer and have it ready to go again. this is not directly for the earth battery  just something interesting i found along my way  ;D  The cool part is this thing charges the caps for my coil gun in about a quarter of the time the camera flash circuit takes.. interesting
hansvonlieven
G'day Joe and all,
Can someone tell me what the diode is doing in this circuit?
Hans
