Localjoe
@Crash
Cool !  ;D if you could take a pic or explain better how you constructed it id be glad to help you as much as i can.
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Bruce_TPU
@ Bill
Radio Shack has mini bulbs, rated at under 9 volts.  I bought some today, as well as the sockets.  I also think that we have to use rechargeable batteries.  But, every experiment is a good one.
I am set up for the same experiment, but I am having to recharge my rechargeable 9 v's.  They were all dead from trying to recharge them using my micro tpu oscillator.
So, Tomorrow evening I will test it out.
@ Crash.
They can be hooked in series only if insulated in cotton, from the dirt.  Series will give you more voltage, but still not much amperage.
Cheers,
Bruce
crash_uni8
i attached the pic....
it's basically a cup of dirt with a couple of screws in it...it gets around .7 volts or so my multimeter says...
and it's connected to the simple little motor...
i can get a reading at the motor end...
my bet it's just not enough juice to get the motor running....
Freezer
Quote from: crash_uni8 on February 17, 2008, 03:46:03 PM
You want to use two different types of metal for your electrodes to get current.  The common metals would be zinc and copper, but there are other metals which do pretty well.  To gain more voltage you need to separate the individual cells and hook them in series.  If you place it in the ground you will have the problem of the cells shorting out.  If you insulate each cell you will gain a little  voltage although not very much and the more moister or rain water in the ground, the more they will short out.  If you use cups of dirt, that will increase the voltage properly so long as it is completely isolated.  I still have cells outside in the dirt which when relatively dry, they put out 3.3 volts, and if raining it falls way down, not even enough to power the led.   If turning that motor is the goal, figure out what minimum voltage it takes to turn it and also the milliamps, then try and achieve that amount of wattage with the cell.
crash_uni8
well it turns pretty well with a AA battery...so maybe 1 volt is the minimal amount....
i still have no idea how many mini amps i need....
[edit] is their someway to increase the amps?
