Rodin Theory & Coils
Started by acerzw, October 28, 2007, 05:26:57 PM
Cloxxki
Quote from: HeairBear on September 25, 2009, 10:10:20 PM
Why hasn't anybody considered experimenting with a Rodin Coil submerged in water? Water molecules are polar and should be affected by the coils EMF possibly creating a small whirlpool. What do you think?
Apart from the odd armchair experimenter, and the above linked vid, you mean? It was condisered, but perhaps people don't try their electrics first in water :-) To my disappointment, water seems to only be scooped up by the neo sphere due to friction, no thrusted water itself. A jetless jet, that would be something...
HeairBear
Would you be as disappointed if you had done the experiment yourself?
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
IotaYodi
Latest Rodin coil put out today by Jamie buturff. Neo sphere stays suspended in air.
http://www.youtube.com/watch?v=Sahi7zDf8Mw
What I know I know!
Its what I don't know that's a problem!
phoneboy
Hello all, new to the forums.  I'm getting ready to make a Rodin coil to do some testing and from what I've seen here there seem to be issues with the inner/outer diameter of the coil and the use of a fixed diameter wire when winding to coil. I believe that the geometry is crucial to get the correct effects  so I figured I would use the Rodin geometry to determine the correct inner diameter of the toroid and use a copper strap/ribbon to make the coils.  I whipped this up in sketchup, looking for input.  The design is for a 20" diameter coil (scalable) based on a Rodin 36 winding, each strap/ribbon is 9 degrees wide and they start in 10 degree increments. See attached images.
Cloxxki
Great graphics, thanks for sharing!
On this page: http://www.energeticforum.com/renewable-energy/4587-marko-rodin-9.html a fascinating alterative to the donut is proposed. Basically a skelleton of 3 ring of different diameters. The whole matches the Rodin enneagram to the dot. And, the visuals offer interesting associations...especially now that Jamie has show that even a collapsed Rodin coil works. So, the proposed tri-ring designs (just how I call it for myself) might be made quite flat. Like a small diner plat?
