Rodin Theory & Coils
Started by acerzw, October 28, 2007, 05:26:57 PM
innovation_station
 ;D
rosphere
dont lose intrest im just round the cornner
and will join the fun verry soon too but i have a few things to take care of first
after that lets start moveing things around the planet and hey who knows maybe across the universe  ;)
what do you say ?
william
Nutcracker
@Rosphere
Ã,  Ã,  Very nicely done coil....Ã,  beautiful.
@All
Ã,   I have put together a pdf of my understanding (very basic) of the coil and the Numerology involved in why it is wrapped the way it is.
Ã,   Pg 1 is the coil setup that Rosphere did.
Ã,   Pg 2 is a coil setup using a different parameter (x = 4).Ã,  This causes the 2nd winding to be done in reverse. (not sure what would affect)
Ã,   Pg 3 is the same as Pg 1 except there are 72 points around instead of 36.... This should give a larger center and have a more circular toroid shape to it instead of the wedge going to the center.
Ã,   Pg 4 is the same as Pg 3 except using the (x = 4) parameter.
Ã,   Pg 5 is a diagram and examples I gleaned from the Roden coil and related information.
Ã,   Again, this is just my understanding... It could be right or wrong.Ã,  Ã,  :-\
Nut
Rosphere
Quote from: innovation_station on November 21, 2007, 09:43:14 AM
what do you say ?
I'm speechless.  ;D
Quote from: Nutcracker on November 21, 2007, 04:58:24 PM
Very nicely done coil....  beautiful.
Thanks, man.  :)
...This should give a larger center and have a more circular toroid shape to it instead of the wedge going to the center.
Or, the wedge, (profile,) may be important.  One never knows...  :'(
No offers yet for the coil.  I may hang-on to it.  If William makes one just like mine then we may finally be on the same wavelength.  :D
After all, I may eventually obtain better equipment.  I would like to get me one of those jdo300-MC-HV-SG units with phase control and automatic ice maker,  ;), when it comes out.
In the meantime, I have been having a bit of fun charging up a cap with my MOT, to a couple hundred volts, and pulsing the coil with one spark-gap burst.  It throws that four-neo-mag assembly, from my 'dry' video, clean out of the ring.  It reminds me of one of our cats when I suddenly move one of my unnoticed feet across the carpet.  Good times.  :D
Rosphere--heavy on the emote-icons lately  :P
Doug1
Rosphere
   Before you rid yourself of the coil perhaps you could run a test. Some where on this site there is a link to video of two guys from cal. who separated out inductive energy from resistive with a test rig made of air inductors and resisters run in series and then in parallel to prove some form of standing wave theory. Im new to this site so where it was is not so easy for me to find.
  Any way perhaps when pure inductance is fed into the coil at or from the beginning or end of one these test rigs it will suck in the corresponding opposite and missing other component which can be drawn through a load be it resistive or inductive depending on how the test rig is set up.
   The one repeating theme seams to be that what is perceived to be energy is actually a collection of different opposing individual energies which combine into useful power by modern day terms of power. If you can draw one of the components by setting up a situation where it is missing in a device that lends itself to being dependent on a balance of both maybe it will pull it in from who knows where.
  I have to go hunt that video link down and try to make some notes to try this out on my cooks coils since I spent the time to make them. I have never tried to make the one you have. I have a couple conical tesla coils I can run the test on also after the thanks giving day none sense is over.
   Have a happy Turkey Day guys
acerzw
@Nutcracker
Nice PDF...
@Rosphere
The aluminum used is typically 4-5mm thick and 12 volts may not be essential....
The magnet vids show a rotating vortex which is a good effect, I would hang on to that coil if I were you... few are patient enough to make a good job of one...
Acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
