Very simple OU device
Started by Turtlefuel, October 30, 2007, 05:17:56 PM
NerzhDishual
@TheNOP
OK.
Actually, if this device generates hydrogen (in any non efficient way) is it not a safe heating engine indeed!
But if this apparatus could be of any OU (COP>1) it is worth to be studied (NRG conservation-wise...) Would It not be?
Best
Nolite mittere margaritas ante porcos.
TheNOP
Quote from: NerzhDishual on October 31, 2007, 08:21:30 PMBut if this apparatus could be of any OU (COP>1) it is worth to be studied (NRG conservation-wise...) Would It not be?
I didn't sayed it was not worte experimenting with.
I was simply stating one reason why this device had been "suppressed".
Solving the hydrogen/oxygen generation "problem", in an ultra safe way, would be require in order for this device to be an accepted alternative to conventional heaters.
This stuff is pretty explosive...
Feeding a full cell with it seems to be technicaly not feasable due to how the gazes are produce.
Burning the hydrogen/oxygen for extra heat could be a way.
Natural gaz heaters safety mecanisimes could be use.
With other mecanisimes specialy made for hydrogen/oxygen.
But in my opignion, water pumps, showing cavitation effect, have a better future as alternative heaters.
TheOne
the hydrogen problem can maybe resolved by using different material, obviously stainless steel is not the way to go
TheNOP
Quote from: TheOne on October 31, 2007, 09:51:40 PM
Is there any conductive material(s) that could prevent hydrogen/oxygen of being generate ?
Turtlefuel
Quote from: TheOne on October 31, 2007, 06:02:02 PM
I like this idea, its really simple!
For a water heater reservoir in a house, you remove the current heater element with this device! But the replication I see from the forum link are not using the same piece. Seam to me that you need 2 different semi bowl, one bigger then another one, and its from the photo the material used is COPPER not stainless steel with bigger space between both bowl.
Yes most of the replications are very poor, including mine :-)
If I knew where to find someone that could build one accurate replica with copper I would pay to get it done. This is weird device and even my simple replication showed some strange effects, one of those being that water was boiled faster than with a the kettle.
For  NerzhDishual , I also did blew many fuses when experimenting. Try to use rain water in your experiments, then there is less electrolysis and less watts consumed.
