Single Wire Tests
Started by duff, October 31, 2007, 03:42:00 AM
0 Members and 80 Guests are viewing this topic.
turbo
Hi Hans,  :)
You have a short circuit going there!!
Take a close look, and dont try that with car battery's  ;D
If you move some points of connection and use high frequency/voltage alternating current it would be also an intresting experiment.
There are always two things on my mind, one of them is Marks Tpu and the other is Hydrogen On Demand.
I keep thinking more about Marks Tpu because it runs without water.
Maybe it's  time for me to start playing with fluid too.....
M.
eldarion
Bruce,
I have a few more questions for you, if you don't mind:
1. Were these two homebrew square wave generators synchronized in any way?  I am assuming that they were not,  which opens up some interesting possibilities.
2. Were they current-limited in any way (resistors, tiny output driver MOSFETs, etc)?  I just want to rule out the possibility of 750mV, 10-amp surges causing the effect. ;)
3. Closely related to #2, what was the approximate resistance of the coil secondary for DC?  High (above 5-10 ohms)?  Or did it appear more like a dead short?
4. Were the square waves unidirectional or bidirectional?  I.E. did the pulses from one square wave generator by itself go both positive and negative or just positive, with respect to zero volts (ground)?
5. And finally, was the output stage of each square wave generator push-pull or some other configuration?
Thanks!
Eldarion
EDIT: If you could tell me the model number of the signal generator kit you used I could probably answer a lot of those questions on my own... :)
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
Bruce_TPU
Quote from: eldarion on January 21, 2008, 05:27:48 PM
Bruce,
Thanks!
Eldarion
Hi Eldarion,
It has been a long time ago, but I will give it a stab.
They were not synchronized.  We used my partners scope to find the frequency of each gen, getting them as close as possible, and then put it on both ends of the coil.
Yes they were all current limited for circuit protection.  My partner built the three of them (he has three) from kits.  I will have to find out what type, or he can post it here.
For question three, I am not sure.  I posted on brnbrade's original thread, before his claim of OU as I attempted to replicate his first description.  On that post, I say how many turns of what size wire for the secondary.  I can't recall right now, but if you find that post, it perhaps would be simple math to determine the resistance based on wire size and length.
Question 4, if I recall, all square waves were positive only.  As shown in the scope picture.
Question 5, I do not know.  I will find out the make of the kit and perhaps that will help.
I am sorry I can't be of more help.   ;)
Cheers,
Bruce
Motorcoach1
Heres something interesting I found and have not seen or missed because it was not listed as we know it and maybe you have seen this .           http://www.youtube.com/watch?v=PTmJpPRprlg&feature=related  .
hansvonlieven
Quote from: -[marco]- on January 21, 2008, 04:37:10 PM
Hi Hans,  :)
M.
Sorry mate,
I should have drawn the LED's in. I thought everybody would get the idea without them. Mind you , the electrolyte will probably act as enough of a load.
My apologies, I'll fix it.
Hans von Lieven
