Telekinetic cell
Started by powermaster, November 01, 2007, 11:22:54 AM
powermaster
hi,
does anyone know about the Telekinetic cell ? http://karma.freewebpages.org/fe_cell.htm I did a search on this forum and nothing came up.
QuoteThe name "telekinetic cell" is assigned to a technical device of my own invention, which (the device) consumes thermal energy that it spontaneously extracts from the environment, and converts this thermal energy directly into electricity. The product of work of such a cell is an electrical energy. In turn the energy that it uses for sustaining its own operation is the heat that it extracts spontaneously from the surrounding air.
I don't know if it works, but from the description it seems it could, because it just converts one form of energy into another so it does not violate any energy conservation laws.
Any comments or info on if these really work?
Koen1
Ah, you've found mr. Pajak's stories and designs. :)
Mr. Pajak presents a few interesting concepts, but he can not substantiate his claims as far as I know.
He has an interesting design for what he calls the "telepathic pyramid", but his claims are somewhat whacky.
He claims that "accelleration of a magnetic field" generates "the telekinetic effect", which is the power that keeps his devices in function. Or so he claims.
Thing is, when you read his "explanation", he describes how a wire that runs parallel to a magnetic field will experience "telepathic" electrical induction when the magnetic field is "accellerated" as he calls it. With this "accellerating" he appears to mean a periodic increase in the magnetic field (strength and area).
So basically he says that when a wire runs trough and parallel to an existing magnetic field, for example between two permanent magnets, and the magnetic field is temporarily increased, for example by temporarily energising an electromagnet coil that is coiled around the wire+magnets, then a force is generated which he prefers to call "telepathic", which will move things including electrons in the direction of the "acclleration", at the region where the magnetic field "ends". And consequently when the "accelleration" is directed oppositely, in other words the existing magnetic field is counteracted to a degree, the electrons should move the other direction too.
Although an electromagnetically induced electron motion seems likely, I doubt this can actually be considered "telekinetic" at all. I don't see any person actively controlling this action with his mental power. Nor do I actually see anything move at a distance, which is what "telekinesis" means...
I seems to recall he also claimed the electron movement caused by this "telekinetic effect" would be extremely low resistance or something like that, but I'm not sure about this... (it has been a few years since I read his docs)
As you may have read in his texts, he also presents a "ufo viewer", and tells of extraterrestrial visitors...
That said, the "telepathic" pyramid device that should also be described on his site, the design of which was apparently "channeled" by some woman from some "extraterrestrial entity", is somewhat interesting.
As I recall it is essentially a self-oscillating system using a pyramid-shaped frame "antenna" with several plates of varying sizes that might well act as capacitor plates, a quartz oscillator which might well act as both basic oscillator and signal amplifier, and a "telepathic circuit" consisting of a vial containing a salt-mercury mix with two electrodes embedded in it, placed between two permanent magnets, and surrounded by an electromagnet coil. The exact function of the salt-mercury vial is not entirely clear to me, but it is suggested this would link up with the human bio-energy field and interact with it, which would cause fluctuations in charge division inside the vial subastance, which would cause electrical current to move through the coil, which would generate the "telekinetic effect", which would in turn cause electrons to flow from (and to) the vials electrodes; the electron flow would then follow the more "normal" path, which means it would probably cause charges to accumulate on the capacitor plates and the pyramid frame itself, which would in turn stimulate electrical oscillation in the quartz connection. The orientation and placement of the magnets may be important here...
In any case, it is claimed this device would then turn into a form of "telekinetic communicator", enabling the user direct (mental?) contact with the receiver through coupling of the bio-(neural?-)energy fields.
Now I am very sceptical about the entire idea of the "telekinetic effect" since I have not observed it in any of my experiments yet.
But the concept of using a pyramid shaped antenna with the right input at the 4 perpendicular axis is something that does interest me, so I have looked at this device.
Also, the use of a 50/50 mix of mercury and NaCl in a sealed glass vial with 2 electrodes at the ends, inside a fluctuating magnetic field, is something that appears not to have been studied by anyone yet. Nobody seems to know what will or does actually happen exactly when one stimulates this mix electrically or magnetically.
It might be worthwile investigating this. Unfortunately I do not have access to mercury, nor do I know anyone who could make me a glass vial with 2 embedded electrodes, and which can be sealed off after filling it with mercury+salt. Melting the glass to seal it is out of the question of course, since it would cause the mercury to expand and partially evaporate. Besides that, one would need to find electrodes of a material that will not amalgamate with the mercury...
That's what I know about Pajak's "telekinetic effect".
What type of energy do you think is converted into what other type of energy?
hansvonlieven
QuoteMelting the glass to seal it is out of the question of course, since it would cause the mercury to expand and partially evaporate.
Not a problem thermometer manufacturers have been doing it for a very long time.
If you need mercury simply buy a mercury thermometer or two, or some electronic mercury switches (all freely available)
Incidentally they contain electrodes that do nor amalgamate with the mercury
Hans von Lieven
Koen1
Yes, mercury switches might be an option indeed... :)
mercury thermometers is harder nowadays, or at least I read that our (Dutch) government has decided mercury thermometers are too dangerous and they're going to try to ban them or something like it...
And Hans, I don't know about you, but I am not a thermometer manufacturer so I do not think I will be able to melt and seal a glass tube of mercury without having quite a bit of the mercury evaporate... ;) Besides, the 'design' states an exact 50/50 mix of NaCl and mecury, if 10% of the mercury evaporates, the thing may not work as claimed... If it works at all of course ;)
karl
Hey,
a mistake: "Crystal radio was NOT able to work without earphones-inductors."
You can use piezoelectric crystalls or sheets (Quarz) instead of the inductors.
There is also an new material on the market, a kind of "single crystal relaxor" material with the properties of PZT but much higher outputvoltages
in several crystal directions.
I think it is a kind of single crystal PZT.
High voltage output at verry low stress in the material.
The Problem: hard to find on commercial market due to the development phase
That works well.
It is nearly sensitive to everything, ion a special shape maybe for a broadband.
Yes, the material itself and it's shape defines the mode of vibration and the bending of the surfaces.
NATURAL MODE SHAPE WAVES are well known.
The question is what should be in resonance with this structure.
Maybe the sound which influences the sensoric system of the body (ELF).
