Hydrosonic Pump
Started by FreeEnergy, June 27, 2005, 03:47:29 AM
allcanadian
Exactly! hold on a minute while I whip a few of these puppy's up.
Can you say engineering problem from hell!
There's got to be an easier design to make this process happen.
IronHead
There is , I will have a few 3d models in a couple days to help explain an efficient design using modern day parts.
Ok I got it. Lets start with cold vaporized water of super fine mist using ultrasonic fogger :)
Just Build It
IronHead
allcanadian
Remember there are issues of embrittlement, large pressure/temperature differentials to contend with, extreme static charges and no more than 3 moving parts.
Piece of cake
Im moving in the same direction so maybe when your done we can compare notes.
Im thinking valvless pulsejet type design with inlet turbine.
IronHead
Yup we are on the same page here. Will have something to show soon.
allcanadian
Hey here's a little know trick I picked up in gas turbine R&D, a single turbine rotor with enough momentum becomes a perfect valve when the flow is reversed. The blade nozzle effect chokes the flow, so with proper geometry it can effectively act like a check valve, one that takes extreme pressure swings with one moving part.
Sweet
