Hydrosonic Pump
Started by FreeEnergy, June 27, 2005, 03:47:29 AM
onthecuttingedge2005
Taken from Wiki, interesting.
The snapping shrimp competes with much larger animals, like the Sperm Whale and Beluga Whale, for the title of 'loudest animal in the sea'. The shrimp snaps a specialized claw shut to create a cavitation bubble that generates acoustic pressures of up to 80 kPa at a distance of 4 cm from the claw. The pressure is strong enough to kill small fish.[7] It corresponds to a zero to peak pressure level of 218 decibels relative to one micropascal (dB re 1 μPa), equivalent to a zero to peak source level of 190 dB re 1 μPa at the standard reference distance of 1 m. Au and Banks measured peak to peak source levels between 185 and 190 dB re 1 μPa at 1 m, depending on the size of the claw.[8] Similar values are reported by Ferguson and Cleary.[9] The duration of the click is less than 1 millisecond.
The snap can also produce sonoluminescence from the collapsing cavitation bubble. As it collapses, the cavitation bubble reaches temperatures of over 5,000 K (5,273.15 degree Celsius).[10] A quick comparison: the surface temperature of the sun is estimated to be around 5,778 K. The light is of lower intensity than the light produced by typical sonoluminescence and is not visible to the naked eye. It is most likely a by-product of the shock wave with no biological significance. However, it was the first known instance of an animal producing light by this effect. It has subsequently been discovered that another group of crustaceans, the mantis shrimp, contains species whose club-like forelimbs can strike so quickly and with such force as to induce sonoluminescent cavitation bubbles upon impact.
TechStuf
What next!   Oh yeah, this....
http://www.youtube.com/watch?v=Zoygy-8PTtU
Truth is stranger than fiction, on so many levels.
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
The water Hammer produces cavitation bubbles that maybe forming fusion bubbles and or Sono-luminescence which is super heating the steam, only nuclear reactions are said to give out over-unity so there might be some bubble fusion cavitation taking place, they could check for Neutron radiation and excess Helium because if so they might be getting a little exposer.
Jerry
TechStuf
Quotethere might be some bubble fusion cavitation taking place, they could check for Neutron radiation and excess Helium because if so they might be getting a little exposer.
Yeah, what he said....
Let's do that!
:D
TS
zed
Quote from: idnick on February 17, 2007, 10:53:01 AM
@ Whitebird
Hope this photo answers some of your questions.
@ TomG
How's your project coming along. I'll post a pic of what I'm up too later
Dave
Dave,
I am working on this project right now can you tell me what was the motor power used in the picture KW/HP ?
Also do you have new updates.
Appreciate it.
Z
