Harmonic Oscillating Power Electric generator video
Started by hartiberlin, June 27, 2005, 07:37:55 AM
hartiberlin
Hi Jim,
the wiring direction per coil is very important.
Did you wire them all right or left turn ?
If you wire one coil left turn and the next one right turn,
it really is a total different device then, cause the flux is
adding or canceling.
So, how did you wind the coils and how did you
place them  ontop the core ?
Are all coils wound into the same direction aroud the core ?
Regards, Stefan.
hartiberlin
Here is an updated version from Jim. He writes:
Hi Stefan,
    Someone pointed out a couple of goof-ups in the HOPE instructions so I fixed them. I've attached the newer updated version for everyone. I'm sure to be doing this again fairly soon so be prepared, lol. I'll try to find out which way the coils were wraped and placed on the core for you as soon as possible. However I'm not going to disasemble anything until the engineer's get here and help design that amp circuit to provide feedback so we can see if we can achieve a loop in the system. Seems like we should be able to but I'm gonna count my chicken's just yet, lol.
Cheers,
Jim
hartiberlin
Hi Jim,
Please can you do the following measurements ?
Take just 60 Hz from an external  transformer and feed
this as the input to the HOPE.
Then note the input AC voltage and the input current via
normal AC-60 Hz meters.
Don?t use any load at the output yet.
Write down  the input voltage and the input current at 60 hz.
Now get a 10 or 50 or  100 Ohm resistor ( with the right wattage)
and put it into the output.
Now again write down the the input voltage and the input current
and also write down the output voltage across the load resistor and
please send me these values, so we can see, how it works.
Many thanks,
Regards, Stefan.
Markus
Hi,
Jim, have you already done the measurements as proposed by Stefan ?
I would really like to see them.
regards,
Markus
hartiberlin
Jim said to me, he fried his DVMs and still has to get new ones.
Hopefully he will soon make this test.
Regards, Stefan.
