Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
FreqShift
@ 4Tesla
Thank you for the welcoming. Hello.
@ btentzer
I do apologize, as my statement was unclear.
I did not mean to infer you were a part of that forum.
The message in that particular sentence,.... was to Mike, if he is watching.
So, I beg your pardon on that wording mistake.
Looking forward to future updates from you and the others.
hakware
@4tesla
Perfect! love the new diagram with the tranny in there. I got a toroid wound with a center tap on it putting it together now. Will give it a whirl and see what becomes of it!
Bruce_TPU
Hello All,
Last update for the night.  My blinker is tired and I'm seeing flashes of blue.   ;D
I tried the circuit with a AA 1.5 volt battery, and had a run time of 14 minutes 40 seconds.  I tried diodes in different spots, but anywhere you put it, it kills the effect, with this circuit anyway.  I think because as EM said at the first, polarity is constantly switching.
I await my transistors I ordered today, and go to LOWES for some iron insulated wire from the garden department.  I also am waiting on some more parts, including a crystal from a crystal radio, germanium diodes and a few other goodies.
Tomorrow, I have only one test planned, and that will be to tie the circuit into earth ground, outside and see what happens.   ;)
Holiday Cheers and good night,
Bruce   ;D
4Tesla
As for transistors I look at the "Min. hFE @ Ic" .  The 2N3904 has a rating of 100 @ .01A and the MPSA18 has one of the best ratings at 500 @ .001A.  That is that it looks like it is more efficient.. I don't understand the hFE value.  The more efficient the transistor is the less power it eats up.
I found this free software for making schematics:
http://www.expresspcb.com/
I found this free SPICE simulator:
http://www.analog.com/en/content/0,2886,0%255F1206%255F162825%255F0,00.html?ref=ASC1285
I haven't tried the simulator yet but the schematic software works great (haven't posted any yet)!  The simulator might support making schematics.
4Tesla
Localjoe
Good odd ball refrence i found that design looks similar to stiffler's circuit just because of the coil ends... figured it might be helpful conceptually
        Joe                      http://leedskalnin.com/Magneticinductionclip.html
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
