Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
Motorcoach1
You need at least  420 ohm resistor  1/4 watt to limit the current to the LEDs . So is the LED a visual aid to let you see it's running or is it running without the LED and you don't know it .
Bruce_TPU
Hi Mike,
There is a 1 Mohm resistor to limit the current, already.
4Tesla
The 1M resistor is for the RC part of the circuit and isn't a current limiting resistor.
4Tesla
Motorcoach1
mmmm tapping finger on laptop .....what was the organial power source in the light sabber .  and as i understand that you hooked it to a 9 volt battery ..... I think the way you have it hooked up is limiting the transistor not the LED
Bruce_TPU
Quote from: Motorcoach1 on December 08, 2007, 07:59:40 PM
Three AA batteries, powering 21 LED's wired in parallel.  (actually stacked and soldered.  It is pretty cool.)
