Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
plengo
800 hours is better, I can wait for that, after all it has been running now for at least a full week, so 3 more to go and a little bit more than what? If it runs for 40 days what does it prove? (no pun intended).
I am still testing some more and watching the voltage and current.
Is there anyone with a battery that was dead for a long time and once on the system would go up? I am about to test that too.
I am not 100% convinced of my own findings because my first version is running pretty good and the light intensity does not seam to change at all, it is very stable. Again it is subjective the perception of light intensity but after 7 days?!!! I will let that baby run for 40 days.
Only time will tell the whole story once I collect enough data and again I will publish it without concerns for my feelings, after all we are looking for the thruth and thats what science is based upon.
Fausto.
Hi Fausto, in your last Youtube video you showed the batteries that worked and some that did not work.
Please can you post here the exact specifications of the batteries, which work ?
Many thanks..
P.S. If the working batteries were really the nonrechargeable Zinc-Carbon type batteries, then I wonder if the effect is due to hitting the graphite electrode with high voltage pulses...
Batteries with graphite electrodes are always special with high voltage pulses...
Groundloop
plengo
@hartiberlin
Now it is running on the carbon zinc and it is still running good. I am totaly confused with this thing. I also tried before with the rechargeble 9v NIMH and it also woked and the final reached voltage was steady and with good charge. So basicaly the good one (let me call it - SRLC "Self Regulator LED Controller") was used with a 9v NIMH and success and now with the 9v Carbon Zinc.
Another replication did not work well with another 7.2v NIHM but seams to be working with another Zinc one.
The zinc one is: Powercell no. 1604P. Manufactured by Gold Peak Industries Limited in China. BTW. I dont think there is HV spikes on this device.
@Groundloop
I did exactly the same as you did and it will keep the gate open. The one that is running good (SRLC) is doing exactly that (edit: keeping the gate charged with an intial voltage and leaking until a certain level) and thats why I said a few posts before that it did not change the brightness in a perceptible way because it has been in the "minimun mode" for a few days already.
Fausto.
Mannix
If there was a way to make the little oscillators spin  it might be more  interesting.
at this stage the fields are going back wards and fowards....like a normal transformer...thats why you get better results with a radio antenna.
Perhaps a larger coil/transformer outside the little ring  would be a better way to pick up the timing pulse?
Of course this only would only spin up like a gyroscope if electrons had inertia......Im not sure that many could agree on that one way or the other.
Google ...cross field antenna...and bhibas...
