Final Draft - Linnard Griffin Hydrogen Reactor Experiment Report
Started by ResinRat2, November 20, 2007, 03:03:55 PM
ResinRat2
Thanks Mike, I have a Harbor Freight store just a couple of miles away. I'll go have a look.
mdh
Thank you for the pdf Mr Rat - it was so well explained that even I understood most of it!  ;)
Tell me -- if i wanted to experiment with this as a fuel supplement, would it produce enough gas to make a difference? ???
ResinRat2
Hi Mdh,
In the size described in the paper, it would not. I am in the process of building a larger sized reactor out of glass to up the gas output. Because I am switching to glass, I am encountering problems I did not expect initially; but things are working out.
The reason I am switching to glass is because I want to improve the heat transfer from the environment into the reactor solution. This should maximize my output efficiency and prove definitively whether the loop is closed and overunity is achieved.
Thanks for your interest.
infringer
Thermite should melt glass and vaporize water fairly quickly :P Wonder if it would produce an excess of hydrogen on the fly ...
I have seen some unexplainable stuff in my day though I've seen the glass cook ware blow up literally just from placing a hamburger in the glass pan that you are supposed to be able to cook in I could not explain it.
Who knows maybe molten led will put holes in glass I will not be the one to say it does not.
But I would guarentee thermite will put holes in glass and then some.
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
darbee63
Not sure what kind of chamber your trying to put a hole in or how big. But why dont you just use a bolt together tube chamber with 4 all thread on flat end plates made of 1/2 in plexiglass with gaskets thats easily drillable and tapable.
Or you could build a hydrogen torch and melt through it, that stuff melts anything on contact.:)
