Some thoughts on how the TPU might work.
Started by dfro, November 26, 2007, 07:43:29 PM
Bruce_TPU
Quote from: Grumpy on January 08, 2008, 05:47:48 PM
The reference to wing design and passing the sound barrier was an "analogy".
Perhaps he meant to imply something like this:
"Along the mach line the millions of small pressure waves add up creating a very strong pressure wave, with highly compressed (dense) air, called a shockwave."
Yes, YES and Yes!  I stated long ago in my thread and hold to it this day that SM wanted us to understand "how" they discovered the correct configuration to break the speed barrier.  Not try to take the actual wing configuration.  IMHO.
These pressure waves, I believe are the accelerator of the electrons.
@ Otto
I think that if you wound your collectors as Litz wire, You would have greater success, if the "phenomenon of magnetic collection" is taking place by rotating the weak magnetic field, visa via the control coil pulses of the three "secret" frequencies.
I have ordered my Litz wire today.  35 ft of 675 strand, individually insulated.  If it is a weak magnetic field causing some of the current in the collector, Litz is the way to go.  Only for the collectors of course.
Cheers,
Bruce
epwpixieq-1
QuoteElectricity travels at 185000 miles per second
Well I do not know what Electricity is ( leave aside the tech books ) and what is it's speed ... I have found this site in one of my searches and it seems to be relevant to give some light on the question: http://amasci.com/miscon/speed.html ... sorry that this may add more to the confusion.
Bruce_TPU
Thanks for posting SM, Chef.
"I want you to start and think of the generator principles the exact
same way that passing the sound barrier was accomplished.
Read how the engineers in this country finally developed the proper wing
design to accomplish super sonic speed in aircraft.
I hope it will give you a picture of what is going on inside the generator
and especially the collector"
How did they develop the wing?  Using pressure waves produced inside of a wind tunnel.  The collector is a circle.  We know that for a fact!  So what is going on inside the collector?  Grumpy said it well.  How?  These three frequencies.  We now have the proper circuit potential with the 3 stack tpu. IMHO
The only things I want to change, is:
a.  Use Litz for the collectors.  And perhaps for the feedback coil as well.
b.  Use 1 tube, with a frequency divider to provide the pulses.
c.  I do not want my control wires connected to the collectors.  I want the current to STOP.   ;)
Cheers,
Bruce
Grumpy
In acoustics waves have "pressure" and "displacement".
In electromagnetics waves have "voltage" and "current".
Respectively, so voltage is pressure and displacement is current.
How does kinetic energy fit in?
        -Frank Edwards
