Some thoughts on how the TPU might work.
Started by dfro, November 26, 2007, 07:43:29 PM
innovation_station
well joe
2.5 hz in my cap charger seamed to work well
now i used a neo relay i made for this porpus
i plused the relay  it made the magnet sing including the coil
it was still singing when the next pluse came round
infact it sounded just as my audio henge did with 3 freqs
and yes i could see feel and hear this effect
i DO NOT recomend anyone try this with the neo as radiation is produced in the expairments i have done
infact i burnt all of the coating off the neo
this can not be a good thing
did it work? yes      was it right? no
however it tought me that 3 freqs are not required
i may produce a video of this  on a lowwwww   voltage scale to demonstrate the ringgggg so you can hear and see what i have seen in this setup
ist
i just thought i would drop this on the end i have always liked this song
if you could read my mind world what a tale my thoughts could tell ..........
http://www.youtube.com/watch?v=97ZbiemJ1KU
if this dont work  try the cash verson   ;)
http://www.youtube.com/watch?v=mdCdSLS6c5M&feature=related
we  will never be set free as long as there is a ghost that you cant see ........
Bruce_TPU
Quote from: Grumpy on January 01, 2008, 03:12:08 PM
What is the "frequency range" of the tubes that SM referenced using when he found the chord (three freqs)?
"Solid state devices are too slow to find the three major intersecting you know whats..."  (Frequencies, meaning more than 1.)
"I am using 6BQ7-A tubes for the input and phase inverter because they are VHF amplifier triodes designed to operate in Color TV at very high frequencies and so you can imagine how crystal clear my high frequencies are in my stereo amplifier.
Yes, I know that they are hard to find so I have found that I can use any triode designed for color TV VHF use.
That gives me many tube types to choose from.
In fact I wouldn't recommend them because they are operated on a six point three volt heater so you could use another tube designed to use a 12.6 volt heater instead.
I prefer using triodes because they generate less distortion.
Any deviation from the original signal or addition to , Harmonic and intermodulation is not good for stereo enjoyment, you know...
Stereo? I have a three channel system I listen to.
Sometimes the three channels combine together to create the most magnificent sound you could imagine."
From the National Tube Museum:
"The 6BQ7A is an all glass miniature VHF double triode and is internally screened.
A valve like this would be used for RF amplification, or frequency multiplication. In the latter case the valve is operated as a non liner amplifier. This causes harmonics of the signal frequency to appear in the anode current. The anode tuned circuit is then chosen to resonate at one of the harmonics, usually the second or third.  (The Collector(s) are the anode tuned circuit!)
The thin glass tube envelope is 19 mm in diameter and excluding the B9A base pins the valve is 49 mm long."
I have not been able to find out the exact frequency range beyond "VHF" as of yet.  I did find out that the 6BQ7-A was used in those old RCA televisions as part of the "Receiver and tuner" circuit.  It made me think of the following:
"a General Electric color television
receiver had been the source of an explosion that killed a young black child in the apartment."
(It used the 6BQ7-A Tube/triode/ in the receiver!) AND
"His theory was that the TV while in operation, somehow managed to become a receiver of more then just television waves and so for a millisecond in time became a receiver and the discharger of a huge amount of electrical and magnetic energy.
This discharge of magnetic energy is vary similar to the discharge of magnetic energy during an atomic explosion. . .
Now that is something I have thought about a great deal."
I think the study of this tube and the electron circuit it was used in the RCA television would be of great importance and revealing.  IMHO
Localjoe
Quote from: Grumpy on January 01, 2008, 10:24:18 AM
"perpetuate the oscillation"
"point of excitation"
"control wiring run or wrapped vertically over the horizontal collector wires"
"They were run in multiple segments."
"fed a different frequency individually and or from a collector section"
"you can measure a slight output even if you do not strike the exact cord"
This is the contex of a link user @marcels left in another post
Observation of single-point excitation and shocking of rotating acoustic waves. (A)
    Peter H. Ceperley and Alon Koren
    Depts. of Phys. and Elec. and Comput. Eng., George Mason Univ., Fairfax, VA 22030
In a cylindrically symmetric resonator or a ring resonator, the proper combination of standing wave modes results in a rotating wave field. Such a field has the appearance of a traveling wave chasing its tail, a constant field profile rotating in space. However, unlike traveling waves, rotating waves are limited to distinct modes. Rotating waves offer the clearest insight into angular momentum and rotary motion in wave fields. The following observations will be reported: (1) rotating acoustic waves in a concentric ring resonator and in a cylindrical resonator; (2) single-point excitation of these waves [P. H. Ceperley, ``Split mode traveling wave ring resonator,'' U.S. Patent 4,686,407 (1987)]; and (3) weak shocking of the wave fronts at acoustic amplitudes near 1 kPa. These all relate to one atmosphere, air-filled resonators. [Work supported by ONR.]
Seemed relevant
And we even get the famous dragon chasing its tail analogy  come on acer i figured youd like this too
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Dansway
wattsup
@all
Who remembers this post back on February 18, 2007.
http://www.overunity.com/index.php/topic,712.msg23740.html#msg23740
This is what I mean by a truck rolling without a steering wheel and SM trying to keep it on the road.
All the Best to All for 2008.
All your dreams WILL be answered for where there is a WILL, there is a WAY.
