Dr. Lindemann?s Electric Motor Secrets DVD
Started by hartiberlin, December 05, 2007, 08:55:19 PM
CTG Labs
Quote from: vzon17 on June 22, 2008, 10:35:32 PM
Actually T bearden figured out how to charge the battery and run the load at the same time. it works on the principle that the ions in the battery have more inertia than the electrons so you can pulse the ions backwards to keep them in position. he said they rosonate up in the megacycle or higher  range.  the way I see it one could devise a switching method and use a super capacitor. battery fills capacitor. battery is momentarily disconnected and reverse pulsed, then reconnected to the capacitor. the load only sees the current flowing steady from the capacitor. it only takes real short bursts of the high frequency to keep the ions in place so the battery stays charged while at the same time you are running a load with the system.
Hi, we have all read Beardens babblings.  I used to be a big follower and read all his papers and books.  But then, where are the working devices?
D.
vzon17
Quote from: CTG Labs on September 14, 2008, 09:30:28 AM
D.
You tell me smarty pants.Where are your working devices and babblings so they can be examined?
CTG Labs
Quote from: vzon17 on September 14, 2008, 12:00:15 PM
Hi,
Well after many years and lots of money I have found nothing strange and have no devices that work outside of accepted principles.  The difference is I don't go round quoting theories as fact with nothing to demonstrate them.
D.
vzon17
Well I guess you are finished then, you have no devices and nothing to demonstrate them.  ;) Only thing you have left then is to make sure nobody else finds anything outside accepted principles either. And become part of the vast army of thought police that dictate and judge what others have done. I think there are enough of those kind of  people out there already. they are the main obstacle to any progress. So you might go find something else to do with your life, since your apparently not doing anything productive in this department anymore. There is no shortage of naysayers in the world at all and they all seem to quote theory as fact also. In fact they tend to quote theory and laws of physics as if they were gospel and often have the same mind set as born again followers. ::) So the "WE" that you are referring to in your reply is who?  :D
magnusx
1. I too conclude that Bearden has nothing, or is not telling anyone if he has - I bought one of his books that supposedly had plans and details only to be sorely disappointed. I could have got the same info free online here, in more detail.
2. The quote at the start of this thread looks fine to me - and even if you only got 65% of the energy back after circuitry losses into a different battery that's still way past "break even", with no "laws of physics" being broken. If you really get the idea of what is going on in electromagnets, you know that no energy is used up by the electromagnet  when a bit of iron is attracted to it, it's the field and not the electricity doing the work, thus when the power in is cut off and a path for it's recovery is provided, you should get most of it back. The alternative is to say that a magnet loses or gains energy when you play around with it, putting bits of metal on it and pulling them away and you know that's not so.
