Bedini replication in Germany
Started by albert, December 08, 2007, 05:08:57 AM
albert
For the winding of the final coils I made another jig with a mechanical counter to count the turns. I found that I could not get a decent winding without a layer of tape between each layer of wire. Each coil holds about 300 feet of wire, the impedance is 1.6 Ohms on the power wires.
I can charge a 100 Amp/hour gel cel type battery that was given to me in a "dead" state (8.5 Volts) and could not hold a charge. Now it can be charged to 15 volts and will run a car headlight bulb. For the primary i sometimes use NiCad cells leftover from my model helicopter. (a 30 cell battery at 40 volts). That battery was completely dead before I used the bedini on it.
Next step is a metallic wheel made on a lathe and milled with slots to hold the magnets.
This is definitely worth building, I have learned a lot in the last 6 months.
bourne
Hi albert
Great looking machine!
Nice pictures as well, thank you for sharing them.
I have only 3 weeks of experience with my single bifilar coil Bedini machine. So it is good to see what can be accomplished in 6 months.
You say in one of your posts that using tape to secure the magnets is not a good idea, and in your first post you mention that the wheel disintegrated at 350 rpm :o
I found in my local hardware shop some "Heavy Duty Fibreglass Reinforced Strapping Tape"
This tape is the business !
I have used it on my wheel, and with my notched out wheel, superglue and this reinforced tape it feels completely solid. I did pull the tape very tight, so as to get flat spots between the magnets.
I am sure, if you use this tape you can let your machine spin up faster without fear of projectiles, which should improve your charging times while keeping your house free of flying magnets ! !
I hope this helps
bourne
There is but one true power in the Universe... that which we call Love. Todays present label and conspicuously absent from our named guardians tool kit.
Rosphere
Quote from: albert on December 08, 2007, 05:33:21 AM
Thank you for sharing your work with pictures.  I think that a Bedini replication is in my near future.
@bourne, thank you for sharing your taping tip as well.
hansvonlieven
Good work Albert and Bourne, keep us posted and thank you for sharing.
Hans von Lieven
albert
Thanks to all of you for your kind reply.
I would like to know if anyone has experience with swapping of batteries on these systems. I know it is not supposed to work but Mr Bedini must be doing it on the big machine he has built or it would be worthless.
I think a lot about the radiant energy phenomenon and the experiments seen in bedini's ENERGY FROM THE VACUUM DVD seem to indicate that it is really a RF phenomenon. The radiant spikes, when expanded on the scope, are really very fast oscillations. That is why there is a skin effect where the energy can leave the conductor. See the demonstration where Mr Bedini lights a small neon bulb between ground and the plastic cover of a battery under charge.
To my laymans view it seems that the famous bi-filar coil can become a low impedance tesla transformer. Because the number of windings on primary and secondary coils is identical, there is no extremely high voltage...Could this be a reasonable theory? Anyway this still does not explain the battery charging effect.
The thing does work as indicated -unlike some other internet-based projects I have seen- and every day I work around it seems to uncover more interesting questions.....I cannot see more energy out than in yet though.
Albert
