Bedini replication in Germany
Started by albert, December 08, 2007, 05:08:57 AM
zott
  I am using a  good simpson true rms meter and it shows  I  am drawing 1.7 amps  at full speed  and  barely get over 1 amp out with  the full resistance at the trigger circuit   . If I drop the 200 Ohm  resistance and only use the 50 ohm  var-resistor I can pull 3.7 amps  to charge batteries with . but  you know the extra  costs   at the drive battery   because I have more rpm's   and  the coils are drawing  4.5 amps .  . so no cigar yet.   I have a couple  ideas  rattling around my noggin  and I have a few 12 hour night shifts to  figure them in.   I have a couple of scopes but have to figure out what I should look for and where . . I think the juice I want shows up just after the transistor closes and the hot power falls off   If the closing fall time is where th cold power sneaks in   I should figure uot how to capture that moment.  does anyone know which scope would be better to do this I have a tektronix 100 mhz ,analogue or a lecroy 400 mhz  digital  to use  and what type of probe ?  I just don't get much time on these machines.
Ren
wicked! ;D Good work. Glad you got it crankin. What is amp draw at running speed?
zott
I really don't know what this is showing yet if anything but OOH ,aah  I will get back to testing and modifying after I go earn some scratch for a few dayz >>zott<<<
Ren
hey zott what happened to all your posts ???
bourne
That is so disheartening zott
It really makes me sad
There is but one true power in the Universe... that which we call Love. Todays present label and conspicuously absent from our named guardians tool kit.
