One of my many pulse motor ideas.
Started by nightlife, December 08, 2007, 11:13:26 PM
nightlife
Pirate88179, I don't have a program and if you could suggest one it would be most appreciated. I had to use my paint and picture programs that came with my computer. I don?t have much experience with these things either but I am learning.
hansvonlieven, you are right about the eddy currents but it has been proven that when you collect the EMF, they stay fairly cool and when you add a cold compressed air flow, it should help even more.
It would take some experimenting to find the right air gap needed between the cylinders and the windings but it should work. As far as the pressure. It wont take much movement to create air pressure and the rate of movement would determine the air flow. Again it would take some experimenting with to determine the best way to utilize it. the second designs would be based on the coil being 100% and the end magnet being 75% of the force of the coil and the air pressure produced should be at least 50% of the coils force.
This was just one of my designs stuck in my head and I thought I would just post these because there are so many working with coils at this time and it maybe something for them to use or help them create other ways to utilize this type of design. It would definitely create more power then it would take to run and that was the whole point of posting it.
nightlife
mramos, copper wouldn't work for the cylinder in these designs but copper windings would. It would take some experimenting to find out what the best material it would take to use as the cylinders. Heat does kill magnets but the cold air flow should help keep them cool.
