Gravity, Magnetism, and BFOs, to power the TPU?
Started by EMdevices, December 10, 2007, 03:53:17 PM
turbo
Quote from: dutchy1966 on December 10, 2007, 06:07:27 PM
Quote from: -[marco]- on December 10, 2007, 06:01:32 PM
an accellerating field with fixed values has never made any sense to me....
Good point !! So it sets up a magnetic field that counteracts the field creted by the dc in the collector?
i do not understand what you mean.
maybe you mean this?
by starting the oscillation you cause the current to flow in the collector which causes the magnification of the process within the collector which will ultimately produce the greater voltage and power in usable amounts during operation.
M.
dutchy1966
Quote from: -[marco]- on December 10, 2007, 06:15:26 PM
M.
The DC current in the collector (the output) creates a magnetic field around the collector. This field needs to be cancelled else electron deflection in the collector can no longer occur..... So the three harmonic frequencies crete a magnetic field opposite to that of the collector. Like thw tpu monitors the magnetic field around the collector and dynamically cancels it....
4Tesla
Assuming the TPU is using the earths magnetic field.. the earths magnetic field has to have a frequency, otherwise you could just use stronger permanent magnets.. correct??
4Tesla
mkt3920
Earth's magnetic field and Color Televisions?
Interesting Patent dealing with "shadow mask", earth's magnetic field bending electron beams, magnetic shielding and  "...involves the placing of magnets on the outside of the tube......."
COMPENSATOR FOR EARTH S MAGNETIC FIELD BY COLOR DOT DISPLACEMENT
http://www.google.com/patents?id=SzlpAAAAEBAJ&printsec=drawing&zoom=4&dq=equator+color+television+magnetic+shadow#PPA3,M1
Another interesting patent with toroids and coils:
(WO/1995/030906) MAGNETIC FIELD CANCELLING SYSTEM
(click on "View", then select the Pages on the top left to see the Drawings, and pages.)
http://www.wipo.int/pctdb/en/wo.jsp?IA=WO1995030906&DISPLAY=DOCS
kames
What you are seeing in the attached image was a test for high speed rotating field. The tpu was specifically designed for it by trying different number of coil turns to satisfy a wide range of frequencies. I tested it with frequencies from 100Hz and up to 12KHz. The phase difference was kept at 90 degrees (and equal amplitude) at all the time with an adjustable pre-amp designed for variable phase shift. The phase difference was measured by using Lissajous figures against the current (not voltage). The entire tpu was powered from the 300W stereo (two channel) audio amplifier. The output was kept at the level of not compromising the quality of the sine signal. A compass placed inside was rotating up to about 1KHz (as long as I remember) input. After that it was stopping because it couldn?t follow the field because of the inertia. At the same time, a copper frame suspended on a thin thread and placed inside the coil was rotating at all the frequencies.
Just a thought.
Kames.
